RBSCP - Anyone have it working?
bennett.troy
I am trying to implement RBSCP on two 3845s running 15.1(4)M1 Adv Enterprise over a satellite link.  The "show" commands all look correct, but whenever I policy route my machine through the RBSCP tunnel I dont even make it to the opposite side.  However, if I remove the "tunnel mode RBSCP" command so it acts like a regular GRE tunnel, I route through it just fine.  So I know its not a NAT, routing issue.  Here are my configs.
Local Side:
object-group network RBSCP_Networks
host 10.10.101.150
object-group service RBSCP_Ports
tcp
132
esp
ahp
ip    (I want to just try to route all traffic through it for now, I have tried it with just TCP and it still didnt work)
ip access-list extended RBSCP
remark TCP-TRAFFIC_ONLY
permit object-group RBSCP_Ports object-group RBSCP_Networks any
deny   ip any any
interface Tunnel200
description RBSCP to Remote
ip unnumbered GigabitEthernet0/0
keepalive 10 3
tunnel source GigabitEthernet0/0
tunnel mode rbscp
tunnel destination 10.10.10.138
tunnel ttl 5
tunnel bandwidth transmit 3500
tunnel rbscp delay
tunnel rbscp window-stuff 1
tunnel rbscp ack-split 4
route-map RBSCP-PBR permit 10
match ip address RBSCP
set interface Tunnel200
interface FastEthernet0/0/0
ip policy route-map RBSCP-PBR
Remote Side:
object-group network RBSCP_Networks_****
host 10.10.101.150
tcp
132
esp
ahp
ip
permit object-group RBSCP_Ports any object-group RBSCP_Networks_****
deny   ip any any
interface Tunnel200
description RBSCP to Local
ip nat inside
ip virtual-reassembly in
keepalive 10 3
tunnel mode rbscp
tunnel destination 10.10.10.137
tunnel ttl 5
tunnel rbscp delay
Show commands for local and remote:
router-local#
sh rbscp all tunnel 200
Tunnel200 is up, line protocol is up
RBSCP operational state:  OPEN
RBSCP operating mode: (26Eh) delay dual_delay ack_split window_stuffing inorder SCTP_report
  window step: 1
  drop scale : 0
  ACK split size: 4
  input drop scale: 2
  initial TSN: 1h
  fuzz factor: 0
  max burst: tunnel 16, network 16
  next TSN: 1h
  next sequence: 4C3h
  current outstanding: 0
  out with no ack: 0
  max out per RTT: 230125
  packets since SACK: 0
  cumulative ack: 133h
  TSN at SACK: 133h
  last cumulative ack: 0h
  last delivered TSN: 133h
  next FWDTSN corr: 4h
  RTO: 680 ms
  RTT: 526 ms     srtt_sa: 4173   srtt_sv: 10
  sentQ: num packets: 0, num bytes: 0
  tmitQ: num packets: 0, num bytes: 0
RBSCP protocol statistics:
  Init FWD-TSNs sent 0, received 1
  TUNNEL-UPs sent 0, received 2
  CLOSEDs sent 0, received 1
  TSNs sent 0, resent 0, lost by sender: gap 0, timeout 0
  TSNs received 2416 (duplicates 0)
  FWD-TSNs sent 1276 (heartbeats 1233)
  FWD-TSNs received 1 (ignored 0)
  FWD-TSNs caused 4 packet drops, 0 whole window drops
  SACKs sent 2419, received 1230 (ignored 0)
  Recovered with RTX 2
  Received with delay 2
  Packets released into: tunnel 3696, network 2416
  Failed sends into the: tunnel 0, network 0
  Most released at once: tunnel 1, network 1
  Dropped due to: excess delay 0, tmit queue full 0
  Dropped detunneled packets 0
  Max on any queue: num packets: 0, num bytes: 0
  Max outstanding: 0
router-remote#
  window step: 1
  drop scale : 0
  ACK split size: 4
  input drop scale: 2
  initial TSN: 1h
  fuzz factor: 0
  next TSN: 1D1h
  next sequence: 1h
  out with no ack: 0
  max out per RTT: 229687
  cumulative ack: 0h
  TSN at SACK: 0h
  last cumulative ack: 1D0h
  last delivered TSN: 0h
  next FWDTSN corr: 0h
  RTO: 679 ms
  RTT: 525 ms     srtt_sa: 4173   srtt_sv: 8
  Init FWD-TSNs sent 0, received 2
  TUNNEL-UPs sent 0, received 1
  TSNs sent 2577, resent 6, lost by sender: gap 0, timeout 4
  TSNs received 0 (duplicates 0)
  FWD-TSNs sent 33 (heartbeats 2)
  FWD-TSNs received 0 (ignored 1314)
  FWD-TSNs caused 0 packet drops, 0 whole window drops
  SACKs sent 1315, received 2574 (ignored 0)
  Recovered with RTX 0
  Received with delay 0
  Packets released into: tunnel 3933, network 0
  Most released at once: tunnel 1, network 0
  Max on any queue: num packets: 5, num bytes: 552
  Max outstanding: 552
Any help would be great
cadet alain
taken from Cisco doc:
If IP access lists (ACLs) are configured on an  interface that is used by an RBSCP tunnel, the RBSCP IP protocol (199)  must be allowed to enter and exit that interface or the tunnel will not  function.
Isn't this the problem ?
Could you do debug ip policy and debug tunnel rbscp.
Regards.
Alain.
