RDP through Cisco 2901
bnelson101
I have a 2901 router that I am trying to configure RDP from the outside.
Currently, I have a DSL connection coming into the router using Dialer1 to connect. The internal server IP is 192.168.115.2 and right now, I am using the default RDP port 3389.
I added the following line but this doesn't seem to be working
IP nat inside source static tcp 192.168.115.2 3389 interface Dialer1 3389
Philip D'Ath
That config is correct.  Is there any access-list or firewall config restricting inbound access?
Can you RDP to the server internally (proving RDP is enabled on the server)?
To All,
Thanks for the responses. It is actually working now with that config. I just saved and rebooted the router and it worked. I am not sure why I have to reboot the router for it to work. Never had to do that before. Anyway, it is working. Thanks.
can you share the rest of your configuration
