Re: To check IP with high utilization on an interface ...
sanjaynadarajah
I would like to know if there is high traffic on an interface ie) serial inteface, what is the
command to check which is the top talker/ relevant IP that is causing this high utilization on this inteface ?
Thank you,
Cheers,
- sn -
If you don't have a netflow analyzer server you can use the ip route-cache flow command.
Configure the ip route-cache flow at the specific interface.
Issue the show ip cache flow command.
To see statiscs by protocol ( do not show the ip address ) configure the command ip nbar protocol-discovery on the selected interface and issue de command sh ip nbar protocol-discovery top-n;
Hope can help.
Please rate the answer.
The better solution for this is Netflow but simple work around is enable
ip accounting command on the interface you will get the top talkers
Hope can help.
