Recommended Router for multiple point to point connections.
kurtzhalsm
I need a router to terminate a T1 internet connection and then 3 other point to point connections. Any recommendations.
globalnettech
Level 5
Level 5
Hello Matt,
have a look at the 2801 in combinaton with an HWIC-4T, which lets you terminate the T1 as well as your other 3 P2P connections. Check this link for details:
Serial & Asynchronous High-Speed WAN Interface Cards for Cisco 1800, 2800, 3800
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd80274416.html
HTH,
GNT
I was thinking about the 2801 with the HWIC-4T for the remote stes off that router what wic and router do you recommend
