Recommended security settings for internet router
carl_townshend
Hi all
I am currently setting up a router for my workplace, A cisco 1800 series, this is to connect to the internet for some clients, what access lists should I put on there from both the in and outside, and should I used cbac etc, an an example would be good.
thanks
Carl
If this will be your Internet router you want to configure an ACL applied inbound to the outside interface permitting only the traffic that should be allowed.
As well, you can have an ACL applied inbound on the inside interface to permit outgoing traffic.
You can use CBAC to inspect the outgoing traffic and allow the returning traffic for the established sessions.
The ACL and the CBAC configuration depends on the devices and services that you will have/provide.
Federico.
