04-27-2007 09:34 PM - edited 03-03-2019 04:45 PM
I have 2811 series router running IP base IOS, later I added VOICE supporting IOS and reload the router.
now the router doesnt boot ; just freezes
Please let me know the steps to restore the router in working mode?? Will I lose my configuration on the router.
Details of router
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory
flash:c2800nm-ipbase-mz.124-3d.bin
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
04-27-2007 10:52 PM
Hi there,
Have you removed the old IOS (IP Base), after add the new Voice IOS ?
BR,
Mohammed Mahmoud.
04-28-2007 06:03 AM
I cannot get the prompt to delete
What steps are required?
04-28-2007 08:15 AM
Thanks God you didn't remove it.
First: reload the router and do a break sequence to enter rommon mode:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
Second: dir your flash to get the old IP-Base IOS exact name:
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html#wp1066200
Third: boot the router using the old IP-Base image:
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html#wp1064046
HTH, please rate if it does help,
Mohammed Mahmoud.
