Recursive Routing
joe.marcelo9
Hello, How to avoid Recursive Routing on GRE Tunnel over ipsec
5 Replies 5
Jerry Ye
You can use static route for the tunnel destination, and/or more specific network statements, and/or distribute-list.
Example to use static route:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094690.shtml#solution
jerry
This hold good for One Tunnel between Hub&Spoke.
How to avoid recursive routing where multiple tunnels from spoke points to central hub on same router with different service providers.
You can do multiple static routes or distribute-list. It is about the same amount of commands.
For distribute-list, you can do something like this, the example is in EIGRP
router eigrp xx
distribute-list prefix TUNNEL_DEST in tunnel y
ip prefix TUNNEL_DEST seq 5 deny a.a.a.a/32
ip prefix TUNNEL_DEST seq 10 deny b.b.b.b/32
ip prefix TUNNEL_DEST seq 100 perm 0.0.0.0/0 le 32
However, filtering routes will be very tricky with OSPF.
HTH,
jerry
Edison Ortiz
Agreed with Jerry. You can also use the WAN facing interface of each endpoint which most likely won't be part of the routing protocol used on the tunnel.
The concept is that the destination IP for the tunnel can't be learned via the tunnel.
It must be learned via the WAN facing interface of such device.
Edison.
Edison,
Agreed to use WAN Interface if its one Tunnel from Hub to Spoke.
Good example of weird scenario already posted on forum, which could be my upcoming concern.
More than one tunnels from Hub points to spoke on same router with different service providers. Spoke Wan interface would be same but HUB with multiple service provider would be with different WAN Interface.
