Redirect request to interface IP address from internal DHCP clients.
varunoberoi
I am running a Cisco Catalyst C8200 Router and I have a static IP address provided by my ISP. I have recently added a web server to my network and configured port forwards for external requests via the static IP.
But when any DHCP client from inside my network tries to visit the static IP, the request gets timed out.
I understand I have to setup an ip route to redirect any internal requests. How would I do that and what does that command look like?
vishalbhandari
@varunoberoi This issue occurs because your internal clients are trying to reach your public static IP, but the router does not NAT hairpin (also known as NAT loopback) by default. Instead of using a static route, you need to configure NAT hairpin so that internal requests to the public IP get redirected to the internal server correctly.
To fix this, update your NAT configuration to allow internal traffic to be translated properly. Assuming your web server has an internal IP of 192.168.1.100 and your external interface is GigabitEthernet0/0, you can modify your NAT rules like this:
cisco
ip nat inside source static tcp 192.168.1.100 80 interface GigabitEthernet0/0 80 ip nat inside source static tcp 192.168.1.100 443 interface GigabitEthernet0/0 443
Then, ensure your LAN interface is marked as ip nat inside and the WAN interface as ip nat outside. If needed, you can also set up a local DNS override so internal clients resolve the server’s internal IP instead of the public one.
5 Replies 5
Share config
MHM
varunoberoi
Router#
*Feb 18 16:58:28.087: %SYS-5-CONFIG_I: Configured from console by consolesh run
Building configuration...
Current configuration : 10797 bytes
! Last configuration change at 22:28:28 IST Tue Feb 18 2025
version 17.6
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
enable secret 9 $SECRET
enable password <password>
no aaa new-model
clock timezone IST 5 30
ip dhcp pool LAN1
network 10.1.0.0 255.255.240.0
default-router 10.1.0.1
dns-server 10.1.0.2 8.8.8.8
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-123123123
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-123123123
revocation-check none
rsakeypair TP-self-signed-123123123
crypto pki trustpoint SLA-TrustPoint
enrollment terminal
revocation-check crl
crypto pki certificate chain TP-self-signed-123123123
certificate self-signed 01
<Long Certificate Info>
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
<Long License Code>
quit
license udi pid C8200L-1N-4T sn FGL2719LFFL
license boot level network-advantage addon dna-advantage
license smart url default
license smart url cslu http://<license_ip_server>/cslu/v1/pi
license smart transport smart
memory free low-watermark processor 67522
diagnostic bootup level minimal
username <password> privilege 15 password 0 <password>
redundancy
mode none
crypto ikev2 proposal std-vpn-proposal
encryption aes-cbc-256
integrity sha1
group 14
crypto ikev2 policy wan1-vpn-policy
match address local xxx.xxx.xxx.xxx
crypto ikev2 policy wan2-vpn-policy
crypto ikev2 keyring wan1-vpn-keyring
peer xxx.xxx.xxx.xxx
address xxx.xxx.xxx.xxx
pre-shared-key XYZXYZXYZXYZ
crypto ikev2 keyring wan2-vpn-keyring
crypto ikev2 profile wan1-vpn-profile
match identity remote address xxx.xxx.xxx.xxx 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local wan1-vpn-keyring
lifetime 3600
dpd 10 5 on-demand
crypto ikev2 profile wan2-hansiwan1-vpn-profile
keyring local wan2-hansiwan1-vpn-keyring
lifetime 3600
dpd 10 5 on-demand
crypto ipsec transform-set std-vpn-TransformSet esp-gcm 256
mode tunnel
crypto ipsec profile wan1-vpn-IPsecProfile
set transform-set std-vpn-TransformSet
set ikev2-profile wan1-vpn-profile
crypto ipsec profile wan2-vpn-IPsecProfile
set ikev2-profile wan2-vpn-profile
interface Tunnel15
ip address 169.254.0.6 255.255.255.255
ip tcp adjust-mss 1350
tunnel source Dialer2
tunnel mode ipsec ipv4
tunnel destination xxx.xxx.xxx.xxx
tunnel protection ipsec profile wan2-hansiwan1-vpn-IPsecProfile
interface GigabitEthernet0/0/0
ip address 10.1.0.1 255.255.240.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 2
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Dialer2
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1442
dialer pool 2
dialer-group 2
ppp authentication pap callin
ppp pap sent-username <username> password 0 <password>
no ip http server
no ip http secure-server
ip forward-protocol nd
ip nat inside source static tcp 10.1.0.3 80 xxx.xxx.xxx.xxx 80 extendable
ip nat inside source static tcp 10.1.0.3 443 xxx.xxx.xxx.xxx 443 extendable
ip nat inside source route-map wan2-nat interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 10.2.0.0 255.255.240.0 Tunnel15
ip access-list extended 100
10 permit ip 10.1.0.0 0.0.15.255 any
ip access-list extended 101
10 permit ip 10.1.0.0 0.0.15.255 10.0.0.0 0.0.1.255
20 permit ip 10.1.0.0 0.0.15.255 10.2.0.0 0.0.15.255
route-map wan2-nat permit 10
match ip address 100
match interface Dialer2
snmp-server community cisco RO
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
stopbits 1
line aux 0
line vty 0 4
password xxxxxxxxx
login
transport input ssh
line vty 5 14
password xxxxxxxxx
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
vishalbhandari
cisco
@varunoberoi
There @vishalbhandari  is correct. you need to use  NAT hairpinning to redirect internal requests back to the server.
let me share my confid also
#ip access-list extended NAT_HAIRPIN
permit tcp 10.1.0.0 0.0.15.255 host xxx.xxx.xxx.xxx eq 80
permit tcp 10.1.0.0 0.0.15.255 host xxx.xxx.xxx.xxx eq 443
#ip nat inside source list NAT_HAIRPIN interface Dialer2 overload
#ip nat inside source static tcp 10.1.0.3 80 xxx.xxx.xxx.xxx 80 extendable
#ip nat inside source static tcp 10.1.0.3 443 xxx.xxx.xxx.xxx 443 extendable
Thanks!
varunoberoi
 So I tried as recommended but the thing that finally worked was setting up a local DNS server. Thankfully we are on a domain controller so setting that up for all clients was simple enough. Thanks.
