Redistribute EIGRP into BGP with dynamic metric
Difan Zhao
Level 5
Level 5
Hi there,
I have a topology that I have an ISR that connects to two ASRs. The two ASRs connect to a FW. between ISR and ASRs they are EIGRP and between ASRs and the FW it is BGP. I do redistribution on the ASRs between EIGRP and BGP.
The problem right now is that to keep the traffic symetrical so outgoing and incoming traffic take the same path/ASR. So right now the redistribution part is static so FW always prefer the path via ASR01 for return traffic. However when I manipulate the delay to prefer ASR02 for outgoing traffic, how do I make the redistribution to reflect the metric change so BGP wise it will also choose ASR02 for the return traffic?
Thanks!
Difan
Difan Zhao
Level 5
Level 5
Never mind... I think if you don't do anything in the route-map, such as "set metric", it will just carry over the EIGRP metric...
Difan Zhao
Level 5
Level 5
if you redistribute EIGRP into BGP with the 'redistribute eigrp 1 metric' command, the BGP return path will reflect the metric and chose the path with the lowest metric. So on either ASR, all you would require is to configure the metric to influence the return path.
ASR1
router bgp 1
redistribute eigrp 1 metric 100
ASR2
router bgp 1
redistribute eigrp 1 metric 200
In the example above, the firewall would prefer the path through ASR1 for all redistributed routes, based on the lower metric.
Does that make sense, and does that apply to your situation ?
Sorry no.. I want it to be more dynamic. With the metric config you would still have to manually change when metric on the EIGRP side changes.. I think I have found a solution for this but this thanks for looking into this
