Redistribute static into BGP issue
HI everyone,
I am occuring a issue of bgp redistribution. There is a static route on Cisco Router 7200 , commands just like as below:
#ip route 12.1.1.0 255.255.255.0  10.1.1.1 tag 10
route-map cisco per 10
 match tag 10
router bgp 12
 redistribute static route-map cisco
the static route can be shown in "show ip bgp" .
After i change the static route ( i add a same static route with tag 20,i think it's can cover the same static route that done before):
ip route 12.1.1.0 255.255.255.0 10.1.1.1 tag 20
  no match tag 10
  match tag 20
router bgp 12
 redistri static route-map cisco
after change the config,i tried to "clear ip bgp * soft ,but there is no that route shown by "show ip bgp " command.
So,i delete the static route,and add it again:
#no ip route 12.1.1.0 255.255.255.0 10.1.1.1
#ip route 12.1.1.0 255.255.255.0 10.1.1.1 tag 20
Then, i tried to "clear ip bgp * soft”,the static route is shown by "show ip bgp "
i want to know what reason about this issue, it's a expected?
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
cisc0.ameer
hi sir
You mean first you wrote something then changed it finally after changing that will not appear in output show ip bgp
How it related to changing ??
what is Your IOS version?
and do you sure when You changed it you did not clear of all them and verify that by
getting show run | s [bgp]
cmarva
Level 4
Level 4
I don't think clearing the protocol will do anything, you would need to be able to clear redistribution, and I don't there's any way to do that other than removing and readding the redistribute line under BGP config.
Hi cisc0.ameer & cmarva
Thanks for your response!
I also think it should be remove and re adding the commands, maybe it can be work well.
BR
Hello
I guess if you cleared the bgb rib with a soft reset then it would have updated accordingly
clear ip bgp * soft
Kind Regards
Paul
