Redistributing sub-set of subnet mind-bender!
john.laham
I have a bit of a mind-bender here, and have searched all over, but can't seem to find a straight answer.
I have a router peered over BGP with another router (this is eBGP) over an IPsec VTI tunnel. I'm receiving a general route from this BGP peer for the 10.0.0.0/16 subnet. Now I want to redistribute only a part of this /16 subnet to another router down the line, meaning that I would like to share something like 10.0.0.0/24 only with this third router, for example.
  1. R1 advertises 10.0.0.0/16 subnet to R2 over BGP
  2. R2 receives advertised 10.0.0.0/16 subnet
  3. R2 now has a route in its route table for 10.0.0.0/16 via R1
  4. R2 wants to advertise subnet 10.0.0.0/24 only to R3, and not he whole /16 subnet
Is this at all achievable?
And if so, how?
Update: I have to highlight the fact that I have no control over R1, as it's controlled by a service provider, with whom I'm peering over BGP.
I have messed around with Conditional Route injection, below are the configs, which probably don't match yours IP address-wise, but the idea of this feature is: a prefix is orignated into the BGP routing table without a corresponding match, based on a condition. In this case, the condition is that a route for 10.0.0.0/16 exists, and based on that condition, 10.0.0.0/24 is injected (and subsequently advertised).
On R3, I have done inbound prefix filtering, you could also do outbound prefix filtering on R2, in order to only receive or send 10.0.0.0/24.
The result of the configs is this routing table on R3:
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 1 subnets
B 10.0.0.0 [20/0] via 192.168.2.1, 00:19:11
B 192.168.1.0/24 [20/0] via 192.168.2.1, 00:19:11
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, GigabitEthernet2/0
L 192.168.2.2/32 is directly connected, GigabitEthernet2/0
R1
interface Loopback0
ip address 10.0.1.1 255.255.0.0
interface GigabitEthernet1/0
negotiation auto
router bgp 1
bgp log-neighbor-changes
network 10.0.0.0 mask 255.255.0.0
network 192.168.1.0
neighbor 192.168.1.2 remote-as 2
R2
ip address 192.168.1.2 255.255.255.0
negotiation auto
interface GigabitEthernet2/0
ip address 192.168.2.1 255.255.255.0
negotiation auto
router bgp 2
bgp inject-map INJECT exist-map EXIST
network 192.168.1.0
network 192.168.2.0
neighbor 192.168.1.1 remote-as 1
neighbor 192.168.2.2 remote-as 3
ip prefix-list INJECTED seq 5 permit 10.0.0.0/24
ip prefix-list ROUTE seq 5 permit 10.0.0.0/16
ip prefix-list ROUTE_SOURCE seq 5 permit 192.168.1.1/32
route-map EXIST permit 10
match ip address prefix-list ROUTE
match ip route-source prefix-list ROUTE_SOURCE
route-map INJECT permit 10
set ip address prefix-list INJECTED
set community 13132:555
R3
ip address 192.168.2.2 255.255.255.0
negotiation auto
router bgp 3
network 192.168.2.0
neighbor 192.168.2.1 remote-as 2
neighbor 192.168.2.1 soft-reconfiguration inbound
neighbor 192.168.2.1 prefix-list INBOUND_FILTER in
ip prefix-list INBOUND_FILTER seq 10 permit 10.0.0.0/24
ip prefix-list INBOUND_FILTER seq 20 permit 192.168.1.0/24
ip prefix-list INBOUND_FILTER seq 30 permit 192.168.2.0/24
15 Replies 15
you could add a route to null for the 10.0.0.0/24 network and use a prefix list to advertise just that network. The config would look something like this:
ip prefix-list OUT_FILTER seq 10 permit 10.0.0.0/24
router bgp 2
neighbor 192.168.1.2 prefix-list OUT_FILTER out
ip route 10.0.0.0 255.255.255.0 null 0
But wouldn't that just send the packets sourced from router R3 destined to 10.0.0.0/24 to the null0 interface on R2?
Because once packets reach R2, R2 will realize that the most specific route it has for this subnet is the one pointing to Null 0.
Yes, you are right. That would have been too easy I guess....:)
I'll look into it further...
Thank you so much for your effort Georg. Would love to hear any ideas you can get regarding this, as it's been really boggling my mind.
R1
interface Loopback0
negotiation auto
router bgp 1
network 192.168.1.0
R2
negotiation auto
negotiation auto
router bgp 2
network 192.168.1.0
network 192.168.2.0
R3
negotiation auto
router bgp 3
network 192.168.2.0
Georg, that is probably the most elegant solution I've seen posted yet.
All this time I was trying to control what gets redistributed into my IGP, what my IGP was advertising, or I was trying to find a way to inject a route into my IGP. But by injecting the "sub-route" into BGP actually gives me a lot more control, as well as the fact that I will be able to better control the failover mechanism down the line, once there is a second BGP peer through a second router to the ISP.
Amazing! Thanks a lot for this. :-)
Hello
One of which will be going to R3, and other carved-out nets will be advertised to other routers (R4, R5, ... Rn) from R2.
@Georg - Nice solution! - however may I ask given the above request-
As this is not neighbor specific, It looks like this would inject the summary and the /24 into any other peers and a their inbound filter would need to be amended to accommodate each advertised /24 and would this solution scale to other peers?
res
Paul
Kind Regards
Paul
Hey Paul, that's not necessarily true because that can be controlled by filtering what goes out of R2 to those other neighbors. This can be achieved in a number of ways, mainly BGP with route-maps would have been my go-to choice, however I'm restricted by project requirements to use an IGP between R2 and the remote routers (i.e. R3, R4, ... Rn).
The solution I developed uses OSPF. BGP is redistributed into OSPF area 0, and every remote router is assigned to another OSPF area. As an example, the VTI between R2 & R3 is in OSPF area 3, rendering R2 an ABR. Next, I configure OSPF on R2 to filter a single prefix to be sent to each area/remote router, accordingly.
Hello
According to you OP, R2 is only receiving a /16 aggregate, as the ISP is suppressing the more specific routes, So R2 doesn't know about them. Its only aware of the summary.
So regarding Georgs last posts, What I highlighted was ONLY a viable statement using BGP as a solution.
Due to the fact using the bgp inject-map xxx exist-map xx globally would advertise the injected /24 prefix to other bgp peers also meaning you have to filter these /24 prefix from the other bgp peers  This I was guess was something you really didn't want to start doing, thus from what i can see it  wouldn't be scalable either.
res
Paul
Kind Regards
Paul
Julio E. Moisa
You could use suppress-map argument on the aggregate-address on R1 (with summary-only), R2 will receive the subnets that you are not suppressing + supernet. Once R2 receive this subnet 10.0.0.0/24 you could easily redistribute into your IGP.
Please let me attach my example.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
For example:
R1
interface Loopback0
ip address 10.0.1.1 255.255.255.0 secondary
ip address 10.0.2.1 255.255.255.0 secondary
ip address 10.0.3.1 255.255.255.0 secondary
ip address 10.0.0.1 255.255.255.0
ip prefix-list SUPPRESS-NETS seq 5 permit 10.0.1.0/24
ip prefix-list SUPPRESS-NETS seq 10 permit 10.0.2.0/24
ip prefix-list SUPPRESS-NETS seq 15 permit 10.0.3.0/24
route-map SUPPRESS permit 5
match ip address prefix-list SUPRESS SUPPRESS-NETS
router bgp 65500
no synchronization
network 10.0.0.0 mask 255.255.255.0
network 10.0.1.0 mask 255.255.255.0
network 10.0.2.0 mask 255.255.255.0
network 10.0.3.0 mask 255.255.255.0
aggregate-address 10.0.0.0 255.255.252.0 summary-only suppress-map SUPPRESS
neighbor 10.12.0.2 remote-as 100
no auto-summary
clear ip bgp * soft
R2
R2 is receiving the allowed prefix and the aggregate subnet.
R2#SH IP BGP
BGP table version is 24, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 2.2.2.2/32 0.0.0.0 0 32768 i
*> 10.0.0.0/24 10.12.0.1 0 0 65500 i
*> 10.0.0.0/22 10.12.0.1 0 0 65500 i
R2#
R2#SH IP ROUTE
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.2.2 is directly connected, Loopback0
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.12.0.0/24 is directly connected, FastEthernet0/0
B 10.0.0.0/24 [20/0] via 10.12.0.1, 00:07:08
B 10.0.0.0/22 [20/0] via 10.12.0.1, 00:06:07
C 10.23.0.0/24 is directly connected, FastEthernet0/1
Once the subnet is on the routing table, you could redistribute into the IGP.
ip prefix-list BGP-->OSPF seq 5 permit 10.0.0.0/24
route-map BGP-->OSPF permit 5
match ip address prefix-list BGP-->OSPF
router ospf 100
log-adjacency-changes
redistribute bgp 100 subnets route-map BGP-->OSPF
network 10.23.0.2 0.0.0.0 area 0
R3
Receive the prefix only.
R3>ena
R3#sh ip route
10.0.0.0/24 is subnetted, 2 subnets
O E2 10.0.0.0 [110/1] via 10.23.0.2, 00:01:58, FastEthernet0/1
C 10.23.0.0 is directly connected, FastEthernet0/1
R3#
Please rate this comment if it is useful :-)
Julio, that's extremely close and thanks so much for the example. There is one issue though, and I guess I should have clarified that in my original post; I have no control over R1, as it's controlled by a service provider, with whom I'm peering over BGP.
The main idea is that I want to be able to "carve out" smaller subnets from the much larger /16 subnet that's being advertised to me. One of which will be going to R3, and other carved-out nets will be advertised to other routers (R4, R5, ... Rn) from R2.
Your approach got me thinking though. Is there a way where I can actually filter parts of the incoming /16 advertised route on R2? For example, if I'm receiving the whole /16 on R2, can it then filter out everything except 10.0.0.0/24, and start working that way.
Or if there is any (better) other way, I'm all ears!
Hello
You didnt specify the how R2 was connecting to R3 so i have assumed it via ebgp
R2
ip prefix-list 10 seq 5 deny 10.0.0.0/8
ip prefix-list 10 seq 10 permit 0.0.0.0/0 le 32
route-map STAN permit 10
match ip address prefix-list 10
ip route 10.10.10.0 255.255.255.0 (r1 isp nexthop)
router bgp 2
network 10.10.10.0 mask 255.255.255.0
neighbor (r3) route-map STAN out
This will basically suppress the aggregate from ISP to be advertised to R3 and with the /24 static applied on R2 you can advertise this /24 prefix from R2.
res
Paul
Kind Regards
Paul
Sure for example if you dont have control of R1, you could use the static route, R2 already know that the subnet 10.0.0.0/24 is part of the supernet and it is being known through R1 so:
R2#Sh ip route 10.0.0.3 --> is a component of the supernet
Routing entry for 10.0.0.0/22
Known via "bgp 100", distance 20, metric 0
Tag 65500, type external
Last update from 10.12.0.1 00:21:34 ago
Routing Descriptor Blocks:
* 10.12.0.1, from 10.12.0.1, 00:21:34 ago
Route metric is 0, traffic share count is 1
AS Hops 1
Route tag 65500
R2#Sh ip route 10.0.1.3  ---> is a component of the supernet
Last update from 10.12.0.1 00:21:37 ago
* 10.12.0.1, from 10.12.0.1, 00:21:37 ago
AS Hops 1
Route tag 65500
Step 1) Create a static route with the specific prefix pointing as next hop the IP of R1 interface.
ip route 10.0.0.0 255.255.255.0 10.12.0.1 tag 70 (I set up a tag 70 but you could use a route-map and set a tag, the tag is optional)
Step 2) Redistribute into the IGP (assuming R2 and R3 are using IGP only, but it could be used for BGP as well (PBR), in my case the IGP is OSPF, for testing purposes I set up the identifier 70.
router ospf 100
redistribute static subnets tag 70
Step 3) Just test :-) , verify R3
R3#sh ip route
3.0.0.0/32 is subnetted, 1 subnets
C 3.3.3.3 is directly connected, Loopback0
O E2 10.0.0.0 [110/20] via 10.23.0.2, 00:05:00, FastEthernet0/1
R3#
R3#sh ip route 10.0.0.1
Routing entry for 10.0.0.0/24
Known via "ospf 100", distance 110, metric 20
Tag 70, type extern 2, forward metric 10
Last update from 10.23.0.2 on FastEthernet0/1, 00:00:17 ago
* 10.23.0.2, from 2.2.2.2, 00:00:17 ago, via FastEthernet0/1
Route metric is 20, traffic share count is 1
Route tag 70
Note
*I have advertised the Loopback0's R3 into BGP on R2 for testing purposes:
R2
router bgp 100
no synchronization
network 2.2.2.2 mask 255.255.255.255
network 3.3.3.3 mask 255.255.255.255
neighbor 10.12.0.1 remote-as 65500
no auto-summary
R2#sh ip bgp
BGP table version is 6, local router ID is 2.2.2.2
*> 3.3.3.3/32 10.23.0.3 11 32768 i
R2#sh ip route
O 3.3.3.3 [110/11] via 10.23.0.3, 00:08:16, FastEthernet0/1
S 10.0.0.0/24 [1/0] via 10.12.0.1
B 10.0.0.0/22 [20/0] via 10.12.0.1, 00:14:59
R1
R1#sh ip bgp
BGP table version is 14, local router ID is 10.0.0.1
*> 2.2.2.2/32 10.12.0.2 0 0 100 i
*> 3.3.3.3/32 10.12.0.2 11 0 100 i
s> 10.0.0.0/24 0.0.0.0 0 32768 i
*> 10.0.0.0/22 0.0.0.0 32768 i
s> 10.0.1.0/24 0.0.0.0 0 32768 i
s> 10.0.2.0/24 0.0.0.0 0 32768 i
s> 10.0.3.0/24 0.0.0.0 0 32768 i
Verify with ping on R3
R3#ping 10.0.0.1 source l0 RE
R3#ping 10.0.0.1 source l0 REpeat 100
Sending 100, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 3.3.3.3
Success rate is 100 percent (100/100), round-trip min/avg/max = 16/22/40 ms
R3#
R3#traceroute 10.0.0.1 source 3.3.3.3 numeric
Tracing the route to 10.0.0.1
1 10.23.0.2 16 msec 8 msec 24 msec
2 10.12.0.1 32 msec * 32 msec
R3#
R3#
And here we go!
