Redistributing VRF routes from BGP into global OSPF
tahscolony
I have a new setup that I am labbing up. I have to add a small MPLS type network into our core OSPF network.  The link between the router and core will be an OSPF neighbor, not part of any VRF, and I want to import routes from one VRF into OSPF, and export routes into VRF from OSPF. All this from just one vrf.
router ospf 1
 router-id 10.10.100.1
 log-adjacency-changes
 redistribute connected
 network 10.10.100.1 0.0.0.0 area 0
router bgp 64518
 bgp router-id 10.10.100.1
 bgp log-neighbor-changes
 neighbor 10.10.100.2 remote-as 64518
 neighbor 10.10.100.2 update-source Loopback0
 address-family ipv4
  neighbor 10.10.100.2 activate
  neighbor 10.10.100.2 allowas-in
  no auto-summary
  no synchronization
  network 10.200.0.0 mask 255.255.255.0
 exit-address-family
 address-family vpnv4
  neighbor 10.10.100.2 send-community extended
 exit-address-family
 address-family ipv4 vrf Public
  neighbor 55.66.77.1 remote-as 4141
  neighbor 55.66.77.1 activate
  no synchronization
 exit-address-family
 address-family ipv4 vrf Internal
  neighbor 10.11.100.0 remote-as 4242
  neighbor 10.11.100.0 activate
  neighbor 10.11.101.0 remote-as 4242
  neighbor 10.11.101.0 activate
  neighbor 10.11.102.0 remote-as 4242
  neighbor 10.11.102.0 activate
  no synchronization
 exit-address-family
 address-family ipv4 vrf External
  neighbor 50.60.70.0 remote-as 4242
  neighbor 50.60.70.0 activate
  no synchronization
  network 66.66.88.0 mask 255.255.255.0
 exit-address-family network 10.200.0.0 0.0.0.255 area 0
These are the networks I want to import
B    172.17.0.0/16 [20/0] via 10.11.101.0, 17:15:40
B    172.16.0.0/16 [20/0] via 10.11.100.0, 17:15:27
B    172.18.0.0/16 [20/0] via 10.11.102.0, 17:15:32
Then I want to be able to filter routes from OSPF into this VRF.  It is the Internal VRF I am interested in.   I tried a route map, didn't work, probably because I need it from the ipv4 vrf and not the main BGP table.
ip prefix-list Internal-BGP-OSPF seq 5 permit 172.16.0.0/16
ip prefix-list Internal-BGP-OSPF seq 10 permit 172.17.0.0/16
ip prefix-list Internal-BGP-OSPF seq 15 permit 172.18.0.0/16
route-map BGP_OSPF permit 10
 match ip address prefix-list Internal-BGP-OSPF
route-map BGP_OSPF deny 50
router ospf 1
redistribute bgp 64518 subnets route-map BGP_OSPF
On a side note, I did get inter vrf routing for the External-Public vrf, but one snag is in order for the filter to kick in I had to reboot the router. Is there another command I need for it to flush the tables for the routes to filter?
access-list 99 permit 9.9.9.0 0.0.0.255
access-list 99 permit 60.70.80.0 0.0.0.255
route-map Public-Export permit 10
 match ip address 99
 set extcommunity rt  1000:4141
tahscolony
Following a different line of thought, if I were to put the interface connecting to the core into the Internal VRF, would I be able to tie OSPF from the core to the routers?  The core is a set of Juniper switches running OSPF only.  I would need to filter traffic to the BGP peers, or summarize them as they have a set prefix limit.  As far as the core network is concerned it is not aware it is touching an MPLS network at that point, am I correct?
