Redistribution from Global to VRF
lakshman.yvv
I am trying to do a Redistribution from Global routing table to VRF routing table.
I can see redistributed routes on my edge routers, however i can not ping.
Configurations are attached to this message.
Any suggestions will be highly appreciated.
Thanks!
sergiudaniluk
You have to add this to your config on the router where you make the redistribution:
ip vrf I
    rd 1000:11
    route-target import 1000:11
    route-target export 1000:11
Best regards,
Sergiu
Hi Sergiu,
Thanks for reply i tried but didnt work. However i can see redistributed routes learned by edge routers.
Here is my router config.
R2#show run
Building configuration...
Current configuration : 2083 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip vrf I
 rd 1000:11
no ip domain lookup
ip tcp synwait-time 5
interface FastEthernet0/0
 ip address 172.16.8.10 255.255.255.248
 duplex auto
 speed auto
interface Serial0/0
 no ip address
 shutdown
 clock rate 2000000
interface FastEthernet0/1
 ip vrf forwarding I
 ip address 192.168.77.9 255.255.255.248
 duplex auto
 speed auto
interface Serial0/1
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/2
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/3
 no ip address
 shutdown
 clock rate 2000000
interface FastEthernet1/0
 no ip address
 shutdown
 duplex auto
 speed auto
router rip
 version 2
 redistribute connected
 redistribute static metric 2
 redistribute bgp 999 metric 2
 network 172.16.0.0
router bgp 999
 no synchronization
 bgp router-id 1.1.1.1
 bgp log-neighbor-changes
 no auto-summary
 address-family ipv4 vrf I
 redistribute rip metric 2
 neighbor 192.168.77.10 remote-as 888
 neighbor 192.168.77.10 activate
 neighbor 213.132.232.123 remote-as 888
 neighbor 213.132.232.123 activate
 no synchronization
 exit-address-family
ip route 192.168.77.0 255.255.255.248 FastEthernet0/1 192.168.77.10
ip route 213.132.232.123 255.255.255.255 FastEthernet0/1 192.168.77.10
ip route vrf I 10.1.1.0 255.255.255.248 FastEthernet0/0 172.16.8.9 global
ip route vrf I 172.16.8.0 255.255.255.248 FastEthernet0/0 172.16.8.9 global
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
