Redistribution Route-map Explanation
roger perkin
Level 2
Level 2
I have an OSPF to BGP / BGP to OSPF redistribution going on between our network and our MPLS provider.
Basic diagram attached.
I am just a bit confused about the route-maps being used for redistribution.
As I understand it the first line of the route map says do not redistribute this address space (access-l 1)
The second line says you can redistribute 10.10.0.0 & 10.11.0.0 subnets
The third line confuses me as I understand it to say redistribute anything else? Or does this just mean a default route?
router bgp
redistribute ospf 1 route-map SET_MED_20K
route-map SET_MED_20K deny 5
match ip address 1
route-map SET_MED_20K permit 10
match ip address prefix-list permit-subnets
set metric 20000
route-map SET_MED_20K permit 30
match ip address 2
set metric 20000
access-l 1 permit 1**.59.0.0
ip prefix-list permit-subnets seq 10 permit 10.10.0.0/16 le 32
ip prefix-list permit-subnets seq 20 permit 10.11.0.0/16 le 32
access-l 2 permit 0.0.0.0
The 1**.59.0.0 is our internet address space
2 Accepted Solutions
Hello Roger,
the third clause of the route-map (permit 30) invokes access-list 2 that matches 0.0.0.0 including default route = 0.0.0.0/0
In IOS the default route is a special case and probably it cannot be passed from a routing protocol to another one.
So statement
doesn't work for 0.0.0.0/0 but it can work for other prefixes that can be matched by first two clauses of the route-map.
so my guess is that later the network route-map statement has been added.
A network route-map statement allows to set some attributes of the route that matches the network command in this case the MED is set to 20000
The first two clauses of the route-map clearly does not apply to prefix 0.0.0.0/0.
Edit:
a more clean configuration could use two different route-maps one used for redistribution of OSPF into BGP and one to be used in the network statement
This is my suggestion.
Hope to help
Giuseppe
Hi Roger,
yes, you are right.
You need to need to add a line to the route-map permitting 10.13.0.0 to get it redistributed to BGP.
Don't forget  if you use
access-list 2 permit 10.13.0.0
for matching, it will permit not only 10.13.0.0/16 but also 10.13.0.0/17, /18,.., /32 (if they exist in your network).
(That's why I'm recommending using prefix-lists instead.)
You can check using sh ip bgp 10.13.0.0/16 longer
command which 10.13.0.0 subnets are present in your BGP table.
HTH,
Milan
6 Replies 6
roger perkin
Level 2
Level 2
Also noticed in the BGP statement
router bgp 6500
no synchronization
bgp log-neighbor-changes
network 0.0.0.0 route-map SET_MED_20K
If anyone can add the relevance of SET_MED_20K in the network statement as well?
Many Thanks
Roger
Hello Roger,
So statement
Edit:
Hope to help
Giuseppe
milan.kulik
Level 10
Level 10
IMHO,
match ip address 2
set metric 20000
does not match anything when
is used.
See
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801310cb.shtml#acclists
or http://www.cisco.com/application/pdf/paws/13750/22.pdf
for details.
That's probably why the network 0.0.0.0 route-map  SET_MED_20K
command was used to get the default route to the BGP table with proper MED - that hopefully answers your second question.
That's interesting the same ACL 2 works when used with the network command but is not working when used with redistribute command.
I'd strongly recommend using prefix-list to avoid all the confusions with ACL syntax here.
HTH,
Milan
So with this current setup woudl this stop a 10.13.0.0/16 network from being redistributed from OSPF into BGP?
I was thinking the 0.0.0.0 entry was covering everything else, but now see this is a default route.
I want to get another subnet into the BGP so do I just need to add a line to the route-map permitting 10.13.0.0 ?
Roger
Hi Roger,
yes, you are right.
HTH,
Milan
Thanks Milan,
This is much clearer now, I was seeing this as permitting the two subnets and then everything else with the 0.0.0.0
I know see this is the default route and if I need to get any other subnets into BGP I will neeed to add another line to the redistribution prefix-list.
I will lab this up and prove it finally and then make the changes I need to.
Thanks guys
Roger
