Redistribution
star1
Hello All,
i am using GNS3 for hands on.
I have router C7200.
I have created OSPF topology and I want to redistribute the  OSPF into BGP but the feature is not available under the BGP, please see the attached file.
Can you help please.
Many thank you.
SS
Try going into address family mode first eg.
address-family ipv4
redistribute ?
Jon
no file attached. Either way, which command is not availabe' 'redistribute ospf' under the BGP process ? Which IOS version are you running on the 7200 ?
Hello Georg,
I use Version 15.2(4)S5.
Yes,'redistribute ospf' under the BGP process in no available.
R4(config)#router bgp 6500
R4(config-router)#?
Router configuration commands:
address-family Enter Address Family command mode
bgp               BGP specific commands
default            Set a command to its defaults
exit              Exit from routing protocol configuration mode
help             Description of the interactive help system
neighbor           Specify a neighbor router
no                  Negate a command or set its defaults
route-server-context           Enter route server context command mode
scope                 Enter scope command mode
snmp                    Modify snmp parameters
template                Enter template command mode
timers                       Adjust routing timers
R4(config-router)#
address-family ipv4
redistribute ?
Jon
Hello Jon,
It worked thank you so much.
