Static routes don't save
nikolai_ursu
Hello, guys!
Routers can't save static routes in CLI. Save only in config tab. But it doent's work this way.
Have I something wrong?
Thanks!
R1#show ip interface brief
GigabitEthernet0/0 10.10.51.1 YES NVRAM up up
GigabitEthernet0/1 192.168.0.1 YES NVRAM up up
GigabitEthernet0/2 unassigned YES NVRAM administratively down down
Vlan1 unassigned YES NVRAM administratively down down
R2#show ip interface brief
GigabitEthernet0/0 10.10.53.1 YES NVRAM up up
GigabitEthernet0/1 192.168.0.2 YES NVRAM up up
could be one of the many bugs in Packet Tracer. Can you post the (zipped) .pkt file ?
sure, posted
--> C 10.10.51.0/24 is directly connected, GigabitEthernet0/0
The static route doesn't show up in the routing table because the same network (10.10.51.0/24) is directly connected, and has a better administrative distance than the static route. Directly connected is preferred.
