Redundant WAN Router setup
jaleelnp
Dear,
I have designed and implemented my organisation with fully redundant/load sharing setup via BGP, but facing small issue like looping and my other remote site which are on same (MPLS cloud) BGP-AS are sending the traffic to only new Backup router which causing off-line to my remote sites.
diagram is attached for your understanding.
I believe expertise guideline and your valuable feedback will correct me to drive properly.
Jaleel Ahmed.
ramkumar62
Consider adding null routes to major subnet to avoid loops
Marwan ALshawi
Can you please provide some more details with routing configuration of both of the routers
For example are using the link with 4 m as back only for inbound traffic from remote sites
Are using as path prepending to achieve this !
