Reg: BGP issue
kuldeep.kaur
Level 3
Level 3
I am having router A which is connected to router b and router c as weel.
They are running in the same as. No sync is also configured. The problem I am having is that on router A the following two networks are advertised.
Network 192.168.1.0 255.255.255.0
ip route 192.168.1.0 255.255.255.0 null 0
when i do a show ip bgp 192.168.1.0 it says it is not advertised to any peer. As such router b and router c is not geting 192.168.1.0 network. These routes are in the bgp table of router a.
The only wired thing i found is they have a route map ibgp-out applied out towards router b and router c. The router map looks like this:
route-map ibgp-out deny 10
There is nothing configured under route-map ibgp out. I am thinking that this is blocking the routes to advertised to router b and c. Am I right. Any suggestions ?
Tks
Jon Marshall
"I am thinking that this is blocking the routes to advertised to router b and c. Am I right."
Yes you are. If you want to allow the route to be advertised either
1) modify route-map to allow it before the deny
2) remove the route-map altogether
Jon
