reg:router
vasuramnet
Dear sir,
Iam looking for router plz suggest me the best router.
A multi port router is required to facilitate connectivity to various applications like Data Terminal (EIN.35), VoIP Equipment, Video Conferencing Equipment, Work Stations etc at each site. It will also provide flexibility to collect data centrally and forward to BEU before data is sent to IDU. The router design should be modular and based on a single unit solution with redundant power supply. It should have following features:
General Features
Mounting 19" RACK Mountable
DRAM Memory 766 MB
Flash Memory 256 MB
Packet Forwarding 150 Kbps or more
Scalability Vacant Slots/serial interface slots for future
scalability
VoIP Support Should support distributed call management Software to provide VoIP solution without requiring an centralized sever/gatekeeper etc.
Interfaces
Ethernet Ports 16 ports of 101100 Ethernet card with POE
capability
Serial Interface
V.35 One Synchronous Serial Interfaces of 2 Mops
V.35
Serial Interface
V.35
E1/T1 Ports One E1 Port (6.703)
Optical Port One Optical GE port at central location only including additional hardware for integration to the router of terrestrial link.
Protocols and Network Management
Protocol support WAN Protocols Support
PPP over Ethernet
Static IP routing support
RIP Version 1 & 2 i
OSPF
IGRP
BGP4
Network Address Translation
DHCP
Multicast Routing Support
Should have lPv4 & IPv6 routing capability
for RIP
Should have IPv4 & IPv6 multicasting
capability
GMP v2 & v3
Real Time Protocols- H.323 v1/v2 and SIP for VoIP and Video Conferencing.
Should support cRTP
Network
Management Web based network management / SNMP
support
plz suggest me which ios and which router is capable to handle this application.
srinivas.D
paolo bevilacqua
This would be, at minimum, a 2821 with the Poe PS, NM-16-ESW-PWR, WIC-1T, VWIC2-1MFT-T1/E1, and a PVDM2-xx correcly size depending on the exact application.
There are voice bundles that includes the PVD2-IS and IOS w/ voice features.
Please contact a cisco reseller to have the exact part list prepared and if you have some doubt ask here.
