Reg: Routing
George K John
I have an application running on a private IP. The IP address is 192.168.2.208 and port numbers are 18082 and 11909
The client software I have installed in the remote place and this system should get access to the server.  I have a public IP 205.20.18.159
I can add this IP to the client system database configuration file.
IP : 205.20.18.159
Port 8282
The below given entry I have done in my ASA. But client is not able to communicate the server.
static (inside,outside) tcp 205.20.18.159 8282 192.168.2.208 18082 netmask 255.255.255.255
access-list acl_in extended permit tcp host 192.168.2.208 any eq 18082
access-list acl_out extended permit tcp any host 205.20.18.159 eq 8282
access-list acl_in extended permit tcp host 192.168.2.208 any eq 11909
Can someone help me?
George
14 Replies 14
cadet alain
you should modify the ACLs like this:
no access-list acl_in extended permit tcp host 192.168.2.208 any eq 18082
no access-list acl_in extended permit tcp host 192.168.2.208 any eq 11909
access-list acl_in extended permit tcp any host 205.20.18.59any eq 18082
access-list acl_in extended permit tcp any host 205.20.18.59 any eq 11909
no access-list acl_out extended permit tcp any host 205.20.18.159 eq 8282
apply the acl_in inbound on outside interface.
Regards.
Alain
Thank you for the update.
I have done another setup.
My Jboss and MsSql server are running on 192.168.2.123 server.
MySql Port is 1433
Jboss Http port 18082
and Tcp 11099
my Public IP is  205.20.18.159
Client system is in the remote place and I can configure the TCP and Http port in client settings file.
Please let me know what are the ACL inbound and outboud to configured in the router
Thanks a lot for your help
George
your new  inbound ACL should be like that:
access-list acl_in extended permit tcp any host 205.20.18.59 any eq 18082
access-list acl_in extended permit tcp any host 205.20.18.59 any eq 1433
access-list acl_in extended permit tcp any host 205.20.18.59 any eq 11099
Regards.
Alain
Thank you so much for the support.
When I use the ACL it says invalid hostname.
access-list acl_in extended permit tcp any host 205.20.18.59 any eq 18080
ERROR: % Invalid Hostname
Can you help me?
George
delete your ACL: no access-list acl_in  then in a text editor make the new ACL then copy paste in tour config
Regards.
Alain
I used the below ACL and it accepted
Still the remote system is saying unable to connect to 205.20.18.59 18080
My doubt is that do we need to create an ACL of http port
access-list acl_in extended permit tcp host 192.168.2.123 any eq http
Any request come to 205.20.18.59 18080 to be forwarded to 192.168.2.123 18080
How do I do this ACL?
George
is the server listening on this TCP port ?
have you got a static PAT entry for this port ?
Regards.
Alain
There is no static PAT configured
nat (inside) 0 access-list inside_outbound_nat0_acl
I have done this entry,
I have my other application running in the same network is working with public IP. Only one difference this applicatio is running on many ports like http, tcp  etc....
George
so you changed the network compared to initial post where you had:
Regards.
Alain
I have done like this
static (inside,outside) tcp 205.20.18.159 11099 192.168.2.208 11099 netmask 255.255.255.255
static (inside,outside) tcp 205.20.18.159 18080 192.168.2.208 18080 netmask 255.255.255.255
I am able to telnet to 205.20.18.159 18080 but not able to telnet to 11099 port.
Can you please tell me where I am making the mistake? I am not an expert in cisco routing part, I am still a learner.
George
do this:
1) first verify the server at 192.168.2.208 is listening on tcp port 11099
2) if it is the case then do this
  packet-tracer input outside tcp 8.8.8.8 1099 205.20.18.159 11099
  post output
Regards.
Alain
Intranet it is working fine. When I  use the public IP it is not working
George
ok so post the output of the packet-tracer command i asked for.
Regards.
Alain
I rectified the problem, now it is working.
Thanks a lot for your suggestion and time
George
