Regarding over subscription
ncnaveen_arasu
While referring the product data sheets, there is some feature called 2:1 over subscribed.
What it means please clarify.
Naveen
5 Replies 5
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
It means, you can push twice as much bandwidth toward some path then it can carry.
For example, imagine a 21 port switch, which has 20 FE copper ports and one gig fiber port.  The 20 FE ports could, in theory, accept twice as much data then the gig port could upload.  So, in that situation, the gig port would be 2:1 oversubscribed.
When reading device specifications, you'll often see how much bandwidth the switch's fabric can handle.  Like the prior example, all the switch's ports might be able to accept more bandwidth than the fabric can pass.
Today, many switch's have fabrics that can handle all their ports without oversubscription, but often uplinks are still oversubscribed.
Leo Laohoo
Good points from Joseph.
When you are dealing with the sales team from a network equipment vendor the question of "over subscription" is seldom asked and it's never mentioned in slide presentation.
Always ask the difficult questions like oversubscription.  If you don't give your SE "white knuckles" then you are not asking the right questions.
Bhishma Khanna
Hi Naveen,
Oversubscription rate is the term used to give the ratio of ASIC to number of ports on the switch or line card.
It could be 8:1 , 4:1 , 2:1 etc.
It means there is one ASIC for 8 ports if the oversubscription rate is 8:1.
Thanks.
Hi Bhishma,
Thanks for your clarification.
But if you refer Joseph explaination 8:1 means one up link port with 8FE with 1 GB uplink port right?
But as per you if 2:1 means one ASIC for 2 ports and 2 :1 will be efficient i hope.
Jon Marshall
Joseph / Leo
If you get the time can you have a look at this thread -
https://supportforums.cisco.com/thread/2260014?tstart=0
being honest, i'm not that great regarding uplinks/fibre to copper convertors on the stackable switches so any advice/recommendations would be much appreciated.
Jon
