Regarding tracert
ncnaveen_arasu
Level 4
Level 4
HI friends,
Tracing the route to google.com (74.125.236.97)
  1 10.255.232.42 4 msec
    10.255.232.38 0 msec
  2 10.255.232.221 12 msec
    10.255.238.237 40 msec
    10.255.235.153 8 msec
  3 10.255.222.225 40 msec
    10.255.221.65 8 msec
    10.255.222.65 12 msec
  4  *  *
In the above output we get an 3 ip's in each hop. what it indicates. Usually trace output shows the ingress IP of each hop.
Thnaks in advance,
Naveen
Abzal
Level 11
Level 11
Hi,http://tools.ietf.org/html/rfc1812#section-4.3.2.4
If I'm not wrong it indicates that your router is multihomed to two routers. And your router is load-balancing these two routers. The router with IP 10.255.232.42 is also multihomed. Can you show you network diagram?
According to RFC1812:
IP source address in an ICMP message originated by the router MUST be one of the IP
addresses associated with the physical interface over which the ICMP message is
transmitted.
Hope it will help.
Best regards,
Abzal
