Reloading a module on a CATOS WS-C6509-NEB
mayambanzumba
Please let me know the command to reload a single module on a CATOS switch with software cat6000-sup2k8.7-6-5.bin
Amit Singh
Please use the command " reset . For example you want to reload the module 4, then use the command
Console> reset 4
Please see the command refrence below:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/cmd_ref/pqr_cmd.htm#wp1031473
HTH,Please rate if it does.
-amit singh
