Remote Access IPSec VPN
MedTiti92
i have a vpn Remote access using Router Cisco 1841, all users can access the all internal servers.
My issues, is how to let some users(for example the user with the username " test1 " access only the server 172.16.1.58 and others access the others servers.
Help !
As always, there are many ways to achieve this. What the best solution is and how to implement it depends on what you already have configured. Sadly you don't tell us.
So here is a simple solution. You have probably something like this configured:
crypto isakmp client configuration group VPN
 key verysecurekey
 domain example.com
 pool VPN-POOL
You configure another VPN like the following:
ip access-list standard SPLIT-TUNNEL
 permit host 172.16.1.58
crypto isakmp client configuration group VPN-2
 key anotherverysecurekey
 domain example.com
 pool VPN-POOL
 acl SPLIT-TUNNEL
If the one user is forced to use this new VPN, he only has access to the systems specified in the ACL SPLIT-TUNNEL.
6 Replies 6
 key verysecurekey
 domain example.com
 pool VPN-POOL
 domain example.com
 pool VPN-POOL
 acl SPLIT-TUNNEL
here is my configuration :
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group Remote
key Re**te$MPlmmre56.sd
pool SDM_POOL_1
acl 101
netmask 255.255.255.0
crypto ipsec transform-set ENC esp-3des esp-sha-hmac
mode tunnel
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ENC
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
route-map SDM_RMAP_1 permit 1
match ip address 100
ip local pool SDM_POOL_1 10.10.0.70 10.10.0.80
ip forward-protocol nd
access-list 100 remark SDM_ACL category=2
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.70
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.71
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.72
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.73
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.74
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.75
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.76
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.77
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.78
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.79
access-list 100 deny ip 10.10.0.0 0.0.0.255 host 10.10.0.80
access-list 100 permit ip 10.10.0.0 0.0.0.255 any
access-list 101 remark Vpn entries
access-list 101 remark SDM_ACL category=4
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
If that is the real Pre-Shared-Key that you just posted in the config, then you should immediately change it.
With that config, it is just the new block of VPN-config:
ip access-list standard SPLIT-TUNNEL-172.16.1.58
crypto isakmp client configuration group Remote2
 pool SDM_POOL_1
 acl SPLIT-TUNNEL-172.16.1.58
don't worry about Pre-Shared-Key, it isn't the real one, the configuration that i send you is the one that all users can access all servers and it works well, i added now another one to specified that one user access only the server 172.16.1.58 :
 domain example.com
 pool VPN
 acl SPLIT-TUNNEL
Unfortunately, i can connect to the vpn, but i can't access 172.16.1.58.
1) Is the POOL the same as with the other users? If not, you likely have to also change your NAT-Exemption.
2) How are you testing to access the server? If you try to reach it by FQDN (like www.example.local) then you also have to add access to your internal DNS-servers.
3) When connected to the VPN, look at the clients routing-table and compare it to one of the regular clients. Do you route traffic to the server to the VPN-adapter?
1 - i tried with same pool and different pool but nothing
2- i do ping to test my access to the server
3- same route-table
unfortunalety no access to my server !
