Remote Telnet Issues
jkitterm
I'm honestly embarassed asking this question but for the life of me I've been unable to resolve the issue. ICMP makes it to ingress but telnet fails from remote subnets. There is another router in front of this device on the same subnet as the ingress, with no ACL's, and this device has no problems with telnet. Anything coming from the internet cannot get a login prompt.
interface FastEthernet0/0
ip address x.x.x.37 255.255.255.248
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.33
line vty 0 4
password cisco
login
I've also tried adding "transport input telnet", but that did not correct my problem.
18 Replies 18
The problem happens even when the config is at it's most basic levels and before I have the LAN segment configured.
Here's the information that you requested though:
ip access-group 100 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
ip address 192.168.2.1 255.255.255.248
ip nat inside
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.2.0 0.0.0.255
access-list 100 permit tcp any host 192.168.2.2 eq 3389
access-list 100 permit icmp any any
access-list 100 permit tcp any any eq telnet
It sounds like your problem is on the Netopia since you can telnet to the cisco from the Netopia. Does it have a FW turned on?
I am starting to believe the problem is with the Netopia, but it's not the configuration. It must be an issue with the 4 port switch on that device. I'm going to try reverting it to factory default - that solution has been known to correct strange problems with the device.
jkitterm
Yeah - it was a bad cable ... yeah ... sorry to waste everyone's time.
