remove username passowrd login on cisco AS5300
ali6359
i have a cisco AS5300 RAS but when switched on at the console, it asks me to enter a username and password. it also says that it was used in a university and gaining access requires an autherised account. obviously, this product has been decomissioned and i own it now. how do i remove the login?
ali6359
problem solved. all i did was took the flash module out and boot the server. once in rommon mode, i entered confreg 0x2142. i then switched off the server and inserted the flash and once i turned it on, i was able to access the RAS without requiring the login
cant access the router and break does not work. i am using PUTTY for console
ali6359
