Remove VLAN from my list
samychihi21
Good evening every body;
I create a new vlan with my packet tracer 5.1; and then i put on it 2hosts
then i remove the hosts to vlan 1 so the new vlan 34 is empty==> i want to remove this vlan from my switch list
Please check the picture below
Reza Sharifi
Hi Samy,
Not familiar with packet tracer but if you have access to the switch via cli, just login and issue these commands:
config t
no vlan 34
Reza
Reza Sharifi
Hi Samy,
config t
no vlan 34
Reza
Thank youuuu very much Reza
you are very helpful.
it is working :-)
Thank you again :-)
Glad to help Samy
Thanks for the rating
