Removing and Installing a Supervisor Engine
Luis Salazar
Community Member
Hi everybody, this time I need your help about Removing and Installing a Supervisor Engine on a cisco router 7690 and more important IOS upgrade of this module.
Please I need some kind of manual, but I would prefer a short procedure to do this change. A brief of the steps to do that.
Also i don't if i have to upgrade the new module after install it.
I really apreciate any comments to help with this. My apologize for my bad english
Luis S.
PD.
IP7VAL02#sh mod
Mod Ports Card                    Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet        WS-X6748-GE-TX     SAL1034Z32J
  2   48  CEF720 48 port 10/100/1000mb Ethernet        WS-X6748-GE-TX     SAL1229XEKU
  3   48  CEF720 48 port 10/100/1000mb Ethernet        WS-X6748-GE-TX     SAL1119NPB9
  4    0  4-subslot SPA Interface Processor-400            7600-SIP-400          JAE1229P8EG
  5    2  Supervisor Engine 720 (Hot)                           WS-SUP720-3B       SAL1033YH6M
  6    2  Supervisor Engine 720 (Active)                       WS-SUP720-3B       SAL1033YL3C
  7    8  Network Analysis Module                              WS-SVC-NAM-2       SAD123600X1
  8    0  4-subslot SPA Interface Processor-400           7600-SIP-400       JAE1340K70V
  9   24  CEF720 24 port 1000mb SFP                       WS-X6724-SFP       SAL1034Z31S
Reza Sharifi
Hi Luis,
Are you trying to upgrade the IOS for your 7609?
If yes, you do not need to remove the Supervisor at all.
1-You just have to find the IOS version you need
2-Load it into the flash card on the both Sup modules
3-Change your boot variable to reflect the new IOS.
4-Save the config
5-Reboot the router
6-After the reboot, make sure that the Sups are in SSO/redunadant mode by issuing "sh red" command
Make sure to do all of these in an outage window, because there will be down time
Reza
Reza Sharifi
Hi Luis,
4-Save the config
5-Reboot the router
Reza
