REP configuration on bridge domain
prima.ramadhan
Hi All,
I have read ES+ configuration guide regarding configuring REP. Its stated that we can configure REP on a bridge domain
Examples
This example shows how to configure REP over EVC using bridge-domain.
Router# enable
Router# configure terminal
Router(config)# interface gigabitEthernet 4/1
Router(config-if)# service instance 10 ethernet
Router(config-if-srv)# encapsulation dot1q 10
Router(config-if-srv)# rewrite ingress tag pop 1 symmetric
Router(config-if-srv)# bridge-domain 100
Router(config-if-srv)# exit
Router(config-if)# rep segment 2 edge
Router(config-if)# end
My question is why cant I configure this on my router:
KGD-NPE-01#sh version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 01:06 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
KGD-NPE-01 uptime is 1 year, 14 weeks, 3 days, 4 hours, 26 minutes
Uptime for this control processor is 1 year, 14 weeks, 3 days, 4 hours, 26 minutes
System returned to ROM by  power cycle (SP by power on)
System image file is "sup-bootdisk:/c7600rsp72043-adventerprisek9-mz.122-33.SRD4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 91750
Enter configuration commands, one per line.  End with CNTL/Z.
KGD-NPE-01(config)#interface GigabitEthernet1/5
KGD-NPE-01(config-if)#service instance 2 ethernet
KGD-NPE-01(config-if-srv)#  encapsulation dot1q 2
KGD-NPE-01(config-if-srv)#  rewrite ingress tag pop 1 symmetric
KGD-NPE-01(config-if-srv)#  bridge-domain 2 split-horizon
KGD-NPE-01(config-if-srv)#exit
KGD-NPE-01(config-if)#rep
KGD-NPE-01(config-if)#rep ?
% Unrecognized command
KGD-NPE-01(config-if)#rep segment 2 edge
% Invalid input detected at '^' marker.
Is there any software requirement for this to happen? As you can see, I am currently use SRD4.
Prima
rsimoni
Hi Prima,
I can configure it on my device (with SRE4 though):
lan-7600-2(config-if)#interface GigabitEthernet7/1
lan-7600-2(config-if)#service instance 40 ethernet
lan-7600-2(config-if-srv)#encapsulation dot1q 333
lan-7600-2(config-if-srv)#rewrite ingress tag pop 1 symmetric
lan-7600-2(config-if-srv)#bridge-domain 32 split-horizon
lan-7600-2(config-if-srv)#exit
lan-7600-2(config-if)#rep ?
  block    Block port & VLANs for VLAN Load-balancing
  preempt  Preemption options
  segment  REP segment ID
  stcn     Segment Topology Change Notification
Is your module 1 an ES+? Can you print a show module please?
If yes, can you try from scratch creating a new instance with new encapsulation?
Riccardo
Hi Ricardo,
Yes my module 1 is ES+ module, otherwise I can not configure EVC right? or there are other modules that can support EVC?
below is my show module:
KGD-NPE-01#sh module
Mod Ports Card Type                              Model              Serial No.
  1   20  7600 ES+                               7600-ES+20G3C      JAE14210EWU
  5    2  Route Switch Processor 720 (Active)    RSP720-3C-GE       JAE14190FDB
  6    2  Route Switch Processor 720 (Hot)       RSP720-3C-GE       JAE14190FT0
I think its because I use IOS version SRD4, while yours are using SRE4. what is your IOS train? mine is advanced IP services SSH.
Prima
same train.
Try to create a new service instance bridging to another vlan to see if the command is available. Or else try an upgrade.
Riccardo
