Replace the core switch
computercenter1
We are going to replace our existing core switch with a newer model, Could some one please share with me what are the best practices to perform this migration peacefully.
ccbootcamp
Level 7
Level 7
Depends on what switch you currently have. Where are you located? Are you working with a Cisco SE and/or partner?
Typically when I think core switch, I think 6509...but it really depends on port density, features needed, connection types. Give me more info.
-brad
www.ccbootcamp.com
(please rate the post!)
Thank you for the response, we are replacing 6500 with 6509-E on the same location and we are working with a partner.
Sounds like you're on the right track. 6509E is a great core switch.
-brad
www.ccbootcamp.com
