02-10-2014 09:54 AM - edited 03-04-2019 10:18 PM
We are looking to replace the above router with a new core routing appliance and wondering what you lot thought? The Sup 720 has issues with Netflow and TCAM and also slow BGP convergance times. We are looking at maybe the ASR 1004 with 40GB route processor or maybe the Nexus 7000. Does anybody have any experiance of using these as core production routers and have any feedback on them?
Or any feisable alternatives to the SUP 720 and not the Sup 2T as that is similar to the 720.
Many Thanks.
02-10-2014 10:16 AM
Do you need a Layer 3 Switch or a Router ?
I would consider the N7K a layer 3 switch. if you have a need for high port density that would work.
I have not seen it in a pure core layer environment, so I cannot comment on its performance.
The ASR is turning out to be a pretty capable device. We have them as DMVPN head ends, and they work just fine.
Purpose build router...
02-10-2014 10:38 AM
It will primerily be used as a router to route alot of internet facing traffic and have alot of BGP sessions homed on it, we will of course need a layer 3 switch card in there too
Im just trying to gather our options, do you run netflow or have any BGP running on the ASR? Any issues of concern?
02-10-2014 11:25 AM
No Netflow, minor instance of BGP.
Our workhorse is the ASR9010.
As Joseph indicated below, it may be worth a look.
02-10-2014 11:13 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There's a little more to the sup2T's architecture vs. sup720. You might not want to rule it out without further analysis.
Beside the ASR 1k series, you could also look at the "small" ASR 9ks.
