replacement for Cisco 877 router
GANT_BELTER
I  called ISP and he told me that they have the technology annex A, and so  I bought a Cisco 877 and still can not configure access to the  Internet. Before there was a ZyXEL 660HW-D1.
ZyXEL is set:
Mode: Routing
Encapsulation: ENET ENCAP
Multiplexing: LLC VPI: 0 VCI: 33
Static IP address: 62.84.142.41
Subnet Mask: 255.0.0.0
Gateway IP address: 62.84.142.1
IP addresses: 192.168.1.1
ip pool: 192.168.1.33 - 99
DNS Servers Assigned by DHCP Server
212.47.0.4
212.47.1.4
(No login passwords)
I can not get internet connection.
please help, thank you
GANT_BELTER
Building configuration...
Current configuration : 5768 bytes
! Last configuration change at 12:29:33 GMT Tue Sep 21 2010 by Gantadmin
! NVRAM config last updated at 10:56:29 GMT Tue Sep 21 2010 by Gantadmin
version 12.4
no service pad
service sequence-numbers
hostname 2P17
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password secret xxxxxxx
no aaa new-model
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
crypto pki trustpoint TP-self-signed-2548630085
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2548630085
revocation-check none
rsakeypair TP-self-signed-2548630085
crypto pki certificate chain TP-self-signed-2548630085
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353438 36333030 3835301E 170D3032 30333031 30303037
  30315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35343836
  33303038 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D21C 5B7C8D00 FA7CCF4E 2E170DBA EABD4355 E3B7E74E 78B00CB9 701A7C4D
  AB651252 B61CB4EF 5697568A 42740B54 687F4036 75605F0C 6F3037B1 9F251B13
  0CAC58F1 1B693F48 4E45597E C415EE12 F73CAFE0 FFCDEC89 93881815 B39FF772
  52EE7836 4AA91136 504D0EDD 04F34B99 532DDE44 7A8083CC BA6E6686 00D139A2
  D1FD0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 146FECB6 D02EC526 D4078B73 1A3E20B4 67CE7D38
  D4301D06 03551D0E 04160414 6FECB6D0 2EC526D4 078B731A 3E20B467 CE7D38D4
  300D0609 2A864886 F70D0101 04050003 81810042 74B26F52 42406669 02379A88
  08A1AF9F 9030101B 4EA886FD E986A308 AFC15DFB 321E52A7 B22E3F7A 592EA789
  E0B52717 C3ADF4E2 B14C89E7 C385E806 2469BA47 A13A1BC8 7192485D 9232FA36
  0C784B45 A5A1C46D AC49FAF7 ACCA6BA7 B49DA286 0CC3D946 271CE55B 0080FFA6
  C2B7DA1C 431D3E9B 0F3F91FF 55725472 647614
        quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip name-server 212.47.0.4
ip name-server 212.47.1.4
username Gantadmin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxx
archive
log config
  hidekeys
interface ATM0
mac-address 404a.03a0.20d1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 62.84.142.41 255.255.255.0
ip nat outside
ip virtual-reassembly
pvc 0/33
  encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 62.84.142.1
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source static tcp 10.2.17.2 5817 interface ATM0.1 5817
ip nat inside source static tcp 10.2.17.2 5917 interface ATM0.1 5917
ip nat inside source static tcp 10.2.17.30 80 interface ATM0.1 5533
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace and with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
