Required urgent help
Hi Expert,
I have one switch WS-C3750G-12S-E. I want to install the c3750-ipservices-mz.122-25.SEC2.bin ios in it.
I have username & password for download the ios, But I am not able to find out this ios on cisco site.
If anyone able to find it, Please provide the path .
Thanks in Advance.
Suryakant
Peter Paluch
Suryakant,
That image is no longer available for download. Please note that the particular IOS version you are looking for is strongly outdated and there may be serious flaws in it. Is there any particular reason for you to require such an old IOS?
Best regards,
Peter
Peter Paluch
Suryakant,
Best regards,
Peter
Hi Peter,
Thanks For your prompt reply.
Actualy Client need this IOS to be installed on switch.
Suryakant.
Hello Suryakant,
Thank you for the generous rating but I don't think I have actually solved your issue...
In any case, I would personally try to find out why the customer needs this precise version. I do not accept the "just because so" as an answer Often, the customer does not really understand what he wants. The oldest available downloadable non-deferred version for 3750 series is 12.2(35)SE5, anyway.
Best regards,
Peter
