Traffic Generator
gbljoba
Does anone know of or reccomend a traffic generator that can send out HTTP, FTP, RTP etc across a WAN? I could use one for my QoS study and LAB. I do remember them having one in the QoS training course but i cant remember the name of it. I think it was a hardware device anyway.
Jon
5 Replies 5
Mohamed Sobair
Level 7
Level 7
Have you seen Ixia Traffic Generator, I havent used it for QoS test , but we used it for Normal IP traffic generator.
Look into this url for more details about Ixia;
http://www.ixiacom.com/
Mohamed
You can use this : http://sourceforge.net/projects/iperf/  or use router(s) with ip sla or TCL to send traffic you wish or use this powerful software to create packets and send them :  http://www.secdev.org/projects/scapy/
regards.
Will NBAR be able to detect the traffic type or are these just sending TCP/UDP traffic on certain ports?
Cheers
Jon
NBAR can detect traffic type loking at L4 but also inspecting packets up to L7
Jon,
As I said, we have used it for normal TCP/UDP traffic generator not at the application level.
Mohamed
