Reset an Interface is in down state
nsylaj
Visitor
I am trying to figure out a script or SLA configuration which applies the Shut/No Shut command if an interface goes down on a cisco switch, 3750
Can anyone guide me on this issue ?
Below is what I have for the SLA Config, however,  the interface is an access vlan and I do not have an IP as far as tracking by IP.   Is it possible to track by Status/Protocol state ?
track 1 ip sla 10 reachability
delay down 10 up 10
ip sla 10
icmp-echo ?????? source-interface Fastethernet 1/0/12
frequency 30
ip sla schedule 10 life forever start-time now
event manager applet Link-Down
event track 1 state down
action 1.0 syslog msg "Reply timed out; Link is down"
action 1.1 cli command "enable"
action 1.2 cli command "conf t"
action 1.3 cli command "interface Fastethernet 1/0/12"
action 1.4 cli command "shut"
action 1.5 cli command "end"
action 1.6 syslog msg "interface Fastethernet 1/0/12 shutdown"
event manager applet Link-Up
event track 1 state up
action 1.0 syslog msg "Ping received; Link is up"
action 1.4 cli command "no shut"
action 1.6 syslog msg "interface Fastethernet 1/0/12 up"
3 Accepted Solutions
Below is the configuration that can be used:
track 1 interface GigabitEthernet1/0/14 line-protocol
event manager applet TEST authorization bypass
 action 1.0 cli command "enable"
 action 2.0 cli command "config terminal"
 action 3.0 cli command "int GigabitEthernet1/0/14 "
 action 4.0 cli command "shutdown"
But then how do you bring it back up? There has to be a condition set on the switch that would trigger the EEM to run the script to "no shut" the interface. You can use something in the syslog to trigger that. But I am not sure what exactly you are trying to solve with this script.
Then you would just need to add this line in the script I provided:
action 5.0 cli command "no shutdown"
You can test both.
7 Replies 7
cofee
Level 11
Level 11
Is it possible to track by Status/Protocol state ? Yes, it is. As long as the feature is supported with the code you are using.
Did you try the script and is it not working?
This script needs an IP address to track ping, however, ping is disabled and  I just want to track the state/protocol and reset.
We have cell phone extenders that periodically go down.   Resetting the interface fixes the issue.
I just wanted a shut/no shut process if the state is down.
I think this might work ?
track 1 interface  Fastethernet 1/0/12 line-protocol
action 1.0 syslog msg "Interface went down"
action 1.5 syslog msg "interface Fastethernet 1/0/12 shutdown"
action 1.6 cli command "no shut"
action 1.7 cli command "end"
action 1.8 syslog msg "interface Fastethernet 1/0/12 up"
You can test both.
