Resetting router password
jiho.a
I would like to know if there's a way to reset the password of router (Cisco MX250) without resetting configurations done already.
Richard Burts
It is not clear in your post, so am I correct in assuming that this is a situation where you do not have the current password and want to recover access to the router? This is frequently referred to as password recovery. I do not have experience with MX250 and perhaps it operates differently, but with the Cisco routers that I do have experience with the password recovery process basically involves booting the router without the router loading the startup configuration. Once the router has booted you should be able to get into privileged mode, load the startup config, and configure new passwords. The result of this is that you do not lose the configurations already done.
Rick
Richard Burts
Rick
Thank you Richard! It worked.
I am glad that my suggestion was helpful. Thank you for confirming that it did work. and Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
