Restrict access to loopback using ACL
ramcm.rr
Hello All,
I have tried to restrict access to loopback interface using ACL's with no luck. Does anyone know how this can be done?
Ram
andrew.prince
Level 11
Level 11
The loopback is a "special" interface.
To limit connectvity you should look into restricting via the Control Plane - BEWARE you break everything if configured incorrectly.  Read the below VERY carefully.
http://www.cisco.com/en/US/docs/ios/sec_control_plane/configuration/guide/12_4t/cps_12_4t_book.html
HTH>
andrew.prince
Level 11
Level 11
HTH>
Andrew is correct.
Think "why" you're doing before doing it.
Thanks Andrew. I will try it
I used management plane protection and it works great!
control-plane host
management-interface FastEthernet4 allow ssh snmp
