Hi All,
can anyone suggest why I only get the first routing update from RIP, I'm just advertising the default route to a remote site.
The remote site receives the RIP route but it then times out as it does not receive any more updates. The timers are set the same at both ends.
4 other sites off the main router work fine. This is a new circuit and router. The remote router is configured the same as the other 4.
John
