RIP not working after client reboot
BradyPassey
I'm running a network that relies on RIP, which then I distribute via OSPF through the rest of my network.  If I reboot a client, the route will briefly show up in the routing table and then disappear.  It does this in multiple routers.  The only way to get it to 'stick' and be stable is to clear the routing table.  I can't even clear the specific range, must do a clear ip route *.  For the life of me, I can't figure out why this is happening, anyone have something similar and offer some advice?
7 Replies 7
luis_cordova
Hi @BradyPassey
The route could disappear because a shorter destination is found. I suspect it could be because there are networks that overlap with others, so I suggest checking the networks and masks, to rule out a false positive.
I think you may be right, although no routes seem to remain in any routing table.  I have redundant L3 switches that are both passing along the rip via OSPF.  I removed the redistribution on the secondary router and that seems to have resolved it.  Just potentially removes my redundancy should the primary switch fail.
Hello
Do you have dual mutual redistribution points?
can you post the configuration for your redistribution-
Are you filtering to prevent route feedback?
Kind Regards
Paul
Hi Paul,
I'm not sure what filtering to prevent route feedback entails, perhaps that's what I need to investigate.  My config is as follows, where the secondary no longer has the rip redistribution.
router ospf 500
redistribute static subnets
redistribute rip
passive-interface default
no passive-interface Vlan505
network x.x.x.x 0.0.255.255 area 0
network x.x.x.x 0.0.0.255 area 0
maximum-paths 1
default-information originate always
Hello
Do you have dual redistribution points in you network, meaning is there more than one ingress/egress exit point (rtrs) performing mutual redistribution rip-ospf?
Also
router ospf 500
maximum-paths 1 <-- whats the reason for this
Kind Regards
Paul
Yes Paul, I do have multiple in/out doing the distribution.  As far as the maximum paths, that was set by a previous colleague, I believe to avoid (potential) load balancing.
Hello
okay it is best practice to implement route filtering when you have such a design so not to probably incur route-feedback ( meaning rip into osof into rip
so your rip routes get redistributed into ospf and then those same routes which are now ospf again are redistributed back into rip the same would apply to ospf- rip
Example-
route-map rip-ospf deny 10
match tag 110
route-map rip-ospf permit 99
set tag 120
route-map ospf-rip deny 10
match tag 120
route-map ospf-rip permit 99
set tag 110
router ospf xx
redistributre rip route-map rip-ospf subnets
route rip
redistribute ospf x route-map ospf-rip metric x
The above would be applied at both redistribution points
Kind Regards
Paul
