RIP v2 Metric Manipulation
gavin.mckee
Can I offset the routes learned from a particular source?
Could you explain how?
Gavin
5 Replies 5
flashsplash
i don't really understand ur question but if it is that u want to manipulate the metric its possible. so please be more specific conserning ur question.
jain.nitin
Level 3
Level 3
Hi You can manipulate the metric of RIP v2 with the help of Offset-List command. syntax is as below: You can increase the metric of a route
offset-list {access-list-number | name} {in| out} offset [type number]
If u need more clarification do let me know.
It it helps do rate this post.
Ninja
Jon Marshall
Hi Gavin
If i understand correctly yes you can offset routes learned from RIP.
Attached is a link covering this.
http://www.cisco.com/en/US/products/ps6441/products_command_reference_chapter09186a00804a71e6.html#wp1126354
These commands apply to both RIPv1 and RIPv2.
Jon
My question was related to applying offset lists to routes learned from a particular source.
Say my RIP routes are learned from two different devices:
172.22.152.129
and
192.168.50.60
So these are my routing information sources.
Can I apply an offet to increase the metric learned via the 192.168.50.60 router?
Gavin
Gavin
Yes, you can apply the offset list against an interface so you would apply it inbound on the interface that connects to the subnet that the 192.168.50.60 router is on.
Jon
