rj45 to rj45 console cable
luispereira75
Hi i want to connect a Macbook pro using a rj45 to rj45 console cable to set up a switch but i don't know what to do and no information about it online only about usb. Can anyone help? Thanks
6 Replies 6
If you have a MacBook Pro, you don't have a serial port. And you can't connect an Ethernet-Port to the serial-port of the switch. You need:
  1. An USB-to-Serial-Adapter (something like this)
  2. A regular Console-cable (the blue one that perhaps came with your switch)
HI i have this cable and its a console cable i just don't know how to set it up in terminal. http://www.amazon.co.uk/StarTech-Cisco-Console-Rollover-Cable/dp/B004Z9YG5W/ref=sr_1_2?ie=UTF8&qid=1413580192&sr=8-2&keywords=rj45+to+rj45+console+cable . Thanks
That's just a console-cable. You have to connect it to a serial port on your computer. For a MacBookPro you need something like that this: http://www.amazon.co.uk/Plugable-Adapter-Prolific-PL2303HX-Chipset/dp/B00425S1H8/ref=pd_sim_computers_2?ie=UTF8&refRID=1SFDM07E5GZ3G5V86983
Hi that works in a pc without serial port too? thanks
Yes, just make sure that the Chip that is used in the adapter is supported for the OS you are using.
ok thanks
