Rookie Router question
Mike Hagans
On a Cisco 2921 you have four slots, EHWIC 0 - 3. how do you know which serial port is which?
EHWIC0 and 1 have a module with two ethernet jacks in it. when i log into the router i see
serial 0/0/0
0/0/1 and 0/1/0 and lastly 0/1/1
how can i tell which is which besides doing a no shut and plugging something in. I'm remote from this site actually... Also, what are the colons? I assume they have to do with the channels of the PRI's connected to them but why would :23 show up and the rest show down for instance.
Thanks again. I know the serial port numbers corellate with the slot numbers i just do not recall.. thanks!!
Hi Mike
http://www.cisco.com/c/en/us/support/docs/routers/3725-multiservice-access-router/62611-c2800-62611.html
should explain the numbering system used on your device.
I hope this helps
Kind Regards
Mark
