03-21-2023 09:12 AM
Hi all,
I am going through one of the CCIE BGP lab practices for route aggregation (CCIE Enterprise Infrastructure Foundation by Narbik). There is one particular lab (under BGP lab 6 task 4). Basically, it asked to configure R2 such that only R1 and R4 can accept the aggregate, whereas R3 will receive the aggregate, but it shall discard it. What troubles me is that I do not believe there is any command under route aggregation for such activity. The only thing I can think of is BGP community no-export function. That said, I do not think EBGP neighbor will discard the prefix after receiving it. I'd appreciate some pointers on that. Many thanks.
Solved! Go to Solution.
03-26-2023
07:02 AM
- last edited on
04-05-2023
03:12 AM
by
Translator
This got my mind twisted so much. First of all, thanks for confirming that I cannot do attributes with different neighbors. Believe me, I was really struggling last night. Today, I looked into this further.
Aggregate-address along will advertise all bgp routes on the aggregator to R1, R3 and R4.
Aggregate-address ... summary-only will block original route on R3 from R4 or vice versa (so 10.1.2.0/24 or 10.1.3.0/24 will not be displayed on R4, whereas 10.1.0.0/24 or 10.1.1.0/24 will not be displayed on R3.).
Aggregate-address ... as-set will block the summary route 10.1.0.0/22 on both R3 and R4
R2(config)#ip bgp-community new-format
R2 (config)#route-map ATT_MAP permit 10
R2 (config-route-map)# set community 100:100
R2 (config)# router bgp 200
R2 (config-router)# neighbor 23.1.1.3 send-community
R2 (config-router)# aggregate-address 10.1.0.0 255.255.252.0 summary-only attribute-map ATT_MAP
R3(config)#ip bgp-community new-format
R3 (config)#ip community-list 1 permit 100:100
R3 (config)#route-map IN deny 10
R3 (config-route-map)#match community 1
R3 (config)#route-map IN permit 20
R3 (config)# router bgp 300
R3 (config-router)# neigbhbor 23.1.1.2 route-map IN in
With the above config, I think this should have worked. But somehow, the denial statement didn't quite pick up that aggregate address to be denied.
If I do add as-set to aggregate-address 10.1.0.0 255.255.252.0 summary-only
Then this will definitely block 10.1.0.0/22, but that should not be the effect of community tagging (by the way, I can see the community tag on R3 with 10.1.0.0/22.).
Ideally, I think we should use either summary-only or nothing at all with the
aggregate-address
command, but definitely without the as-set. Then we establish a community tag so that the denial statement on R3 or R4 can block the summary route from the aggregator R2, which is exactly the config above. Somehow, it just ain't working. I knew you had been a great mentor on this for me for the past week (I learned so much on bgp aggregate address attribute.), but at this point of time, I'd appreciate a straight answer pointing out what I had done wrong. Many thanks.
03-26-2023 07:58 AM
Dont worry I will run same code you enter and check.
03-26-2023
12:31 PM
- last edited on
04-05-2023
03:25 AM
by
Translator
R2 (config-router)#
neighbor 23.1.1.3 send-community both <<- this need only
Also run
Bgp new format in both routers
03-26-2023
09:06 PM
- last edited on
04-05-2023
03:26 AM
by
Translator
network 13.1.1.0 mask 255.255.255.0
network 23.1.1.0 mask 255.255.255.0
network 24.1.1.0 mask 255.255.255.0
neighbor 13.1.1.1 remote-as 100
neighbor 23.1.1.3 remote-as 300
neighbor 24.1.1.4 remote-as 400
Still no good. Did it work on yours?
03-26-2023
11:32 PM
- last edited on
04-05-2023
03:26 AM
by
Translator
Yes it work and from first time
Just do
Clear ip bgp x
And check again' some filter need clear ip bgp to take effect
03-26-2023 11:38 PM
Morning, yes, I have done so mulitple times. If you don't mind, can you show me your complete config so that I do a complete comparison?
03-26-2023 11:48 PM
Sure when I have time I will share lab
03-26-2023 11:57 PM
Mostly appreciated.
