Route Leaking Between Global Routing Table and VRF issue
cdicesare
I make a lab on GNS3 for training about route leaking between the global routing table and the VRF cust2.
The topology is simple. There are 3 routers :
-R1 represents the Internet router. He have some loopback interfaces in the IP range 212.x.x.x
-R2 implements two VRF (with cust2 VRF)
-R3 and R4 are simple routers running OSPF. Each one is on different VRF. In our case R4 is in cust2 VRF.
-A peering BGP is performed between R1 and R2.
In R2 all BGP routes exists in the routing table.
My goal is to import all BGP routes which exist in the global routing table of R2 to the VRF cust2 of R2.
I was inspired by this document http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fs_bgivt.html
Here the configuration of R2
ip cef
ip vrf cust1
rd 1000:1
ip vrf cust2
rd 1000:2
import ipv4 unicast map bgp2vrf-cust2
interface Ethernet0/0
ip vrf forwarding cust1
ip address 192.168.3.1 255.255.255.0
half-duplex
interface Ethernet0/1
ip vrf forwarding cust2
ip address 192.168.2.1 255.255.255.0
half-duplex
interface Ethernet0/2
half-duplex
router ospf 1 vrf cust1
log-adjacency-changes
network 192.168.3.0 0.0.0.255 area 1
default-information originate always
router ospf 2 vrf cust2
redistribute bgp 199 subnets
network 192.168.2.0 0.0.0.255 area 2
router bgp 199
bgp log-neighbor-changes
neighbor 192.168.1.2 remote-as 200
address-family ipv4
  neighbor 192.168.1.2 activate
  no auto-summary
  no synchronization
  network 192.168.1.0
exit-address-family
address-family ipv4 vrf cust2
  no synchronization
exit-address-family
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip route 192.168.3.0 255.255.255.0 Ethernet0/0
ip route vrf cust1 0.0.0.0 0.0.0.0 192.168.1.2 global
ip prefix-list bgp2vrf-cust2 seq 5 permit 212.0.0.0/8
ip prefix-list bgp2vrf-cust2 seq 100 permit 0.0.0.0/0 le 32
route-map bgp2vrf-cust2 permit 10
match ip address prefix-list bgp2vrf-cust2
Here some show commands
R2#show ip bgp
BGP table version is 11, local router ID is 192.168.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 192.168.1.0      0.0.0.0                  0         32768 i
*                   192.168.1.2              0             0 200 i
r> 192.168.1.1/32   192.168.1.2              0             0 200 ?
*> 212.1.1.0        192.168.1.2              0             0 200 ?
*> 212.1.2.0        192.168.1.2              0             0 200 ?
*> 212.1.3.0        192.168.1.2              0             0 200 ?
*> 212.1.4.0        192.168.1.2              0             0 200 ?
*> 212.1.5.0        192.168.1.2              0             0 200 ?
R2#
R2#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.2 to network 0.0.0.0
B    212.1.1.0/24 [20/0] via 192.168.1.2, 00:24:27
B    212.1.3.0/24 [20/0] via 192.168.1.2, 00:24:27
B    212.1.2.0/24 [20/0] via 192.168.1.2, 00:24:27
B    212.1.5.0/24 [20/0] via 192.168.1.2, 00:24:27
B    212.1.4.0/24 [20/0] via 192.168.1.2, 00:24:27
C    192.168.1.0/24 is directly connected, Ethernet0/2
S    192.168.3.0/24 is directly connected, Ethernet0/0
S*   0.0.0.0/0 [1/0] via 192.168.1.2
R2#show ip vrf cust2
  Name                             Default RD          Interfaces
  cust2                            1000:2              Et0/1
R2#show ip route vrf cust2
Routing Table: cust2
Gateway of last resort is not set
C    192.168.2.0/24 is directly connected, Ethernet0/1
R2#show ip prefix-list detail
Prefix-list with the last deletion/insertion: bgp2vrf-cust2
ip prefix-list bgp2vrf-cust2:
   count: 2, range entries: 1, sequences: 5 - 100, refcount: 3
   seq 5 permit 212.0.0.0/8 (hit count: 0, refcount: 1)
   seq 100 permit 0.0.0.0/0 le 32 (hit count: 0, refcount: 1)
R2#show route-map
route-map bgp2vrf-cust2, permit, sequence 10
  Match clauses:
    ip address prefix-lists: bgp2vrf-cust2
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
R2#show ip vrf detail
VRF cust1; default RD 1000:1; default VPNID <not set>
  Interfaces:
    Et0/0
  Connected addresses are not in global routing table
  No Export VPN route-target communities
  No Import VPN route-target communities
  No import route-map
  No export route-map
  VRF label distribution protocol: not configured
VRF cust2; default RD 1000:2; default VPNID <not set>
  Interfaces:
    Et0/1
  Import route-map for ipv4 unicast: bgp2vrf-cust2 (prefix limit: 1000)
  No export route-map
Do you have an idea of the problem ? I want just import the global BGP route on the VRF cust2, the import doesn't work.
Thank you by advance for your help.
Cédric
Hi Cedric,
You do not have to close the discussion - you may leave it as is.
However, your solution puzzles me... I've been doing some experiments to verify the behavior of route leaking from the global routing table into a VRF to chcek what is wrong on your configuration, as I didn't see anything suspicious. I certainly did not configure the route distinguisher to use the same ASN as the BGP process, and yet in my configuration, the route leaking was working properly.
Will the route leaking stop working again if you return the original route distinguisher with the different ASN to your cust2 VRF?
Best regards,
Peter
5 Replies 5
cdicesare
I have found the error.
The RD in VRF cust2 was bad because it doesn't correspond with the BGP ASN.
ip vrf cust2
rd 199:2
How can I close this discussion ?
Hi Cedric,
Best regards,
Peter
I launched again my lab and tryed to re test with
ip vrf cust2
rd 1000:2
and it's works !! I don't know why it didn't work at a moment...
R4#show ip route
Gateway of last resort is 192.168.2.1 to network 0.0.0.0
O E2 212.1.1.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
O E2 212.1.3.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
O E2 212.1.2.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
O E2 212.1.5.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
O E2 212.1.4.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
O E2 192.168.1.0/24 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
C    192.168.2.0/24 is directly connected, Ethernet0/0
O*E2 0.0.0.0/0 [110/1] via 192.168.2.1, 00:04:16, Ethernet0/0
Thank you for your help
Hi Cedric,
It may be a glitch in the IOS you are using, or perhaps the import map is evaluated only when the routing table is modified, so perhaps a change to the routing table was all that was needed to actually make the route leaking to 'kick-in'.
Nevertheless, I am happy that you got it running.
Best regards,
Peter
Hi Peter,
Thank you for your reply. I think your are right. In more, I make the lab on a virtual environnement (GNS3/dynamips), perhaps it may be due to a slowness of my PC.
Thank your for your help.
Cédric
