Route map, prefix list, order of commands..
MicJameson1
GIVEN: config...
Conf t
ip prefix-list BLOCK-ANYCONNECT-SLASH-32-SUBNETS seq 10 permit 172.16.77.0/24 ge 32
ip prefix-list PERMIT-ANYCONNECT-SLASH-24-SUBNET seq 10 permit 172.16.77.0/24
route-map RM-BLOCK-ANYCONNECT-SLASH-32-ROUTES deny 10
match ip prefix-list BLOCK-ANYCONNECT-SLASH-32-SUBNETS
route-map RM-BLOCK-ANYCONNECT-SLASH-32-ROUTES permit 20
match ip prefix-list PERMIT-ANYCONNECT-SLASH-24-SUBNET
!! (below final statement is empty to allow all other prefixes) !!
route-map RM-BLOCK-ANYCONNECT-SLASH-32-ROUTES permit 30
router eigrp 1
distribute-list route-map RM-BLOCK-ANYCONNECT-SLASH-32-ROUTES out
Questions:
1. Will this config accomplish intent of preventing EIGRP distribution of
172.16.77.0/32
routes, and also permitting and propagating the advertisement of the
172.16.77.0/24
network?
2. Is the red text needed to create
172.16.77.0/24
advertisement, or can it be ignored?
Thank you.
Hello @MicJameson1 ,
Regarding...
Is this above config necessary to advertise the subnet via EIGRP?
No it is not necessary as I have written before prefix
172.16.77.0/24
would be permitted by last
route map
block
>> If this wasn't in the
route map
would the
/24
subnet be advertised?
Yes , it would still be advertised thanks to last block permit 30 with no match statements
Is it still necessary to advertise the
/24
subnet via...
ASA5525#router eigrp 1
network 172.16.77.0 255.255.255.0
To answer to this question you need to ask yourself if the ASA is injecting a
default route
in EIGRP routing domain, the specific route for the remote VPN pool is not necessary. If the ASA is not in the path for general internet connectivity that route is needed as the
default route
would point to some other device / path
Hope to help
Giuseppe
Giuseppe Larosa
2) the block is not strictly needed as the last
route-map
block would allow also
172.16.77.0/24
You can consider it just a way to make the configuration more easy to understand
1) Yes, the configuration should work I thought I had suggested you to put the red block first, then the deny block and then the final permit but your configuration works too.
Hope to help
Giuseppe
Regarding...
route map
would the
/24
/24
subnet via...
Regarding...
172.16.77.0/24
route map
block
route map
would the
/24
/24
subnet via...
default route
default route
Hope to help
Giuseppe
