Route maps
John Blakley
All,
I'm a little confused about route map functionality with regards to the deny statement. Do the following all do the same thing?
Ex. 1:
access-list 5 deny 1.1.1.0 0.0.0.255
access-list 5 permit any
route-map TEST permit 5
match ip address 5
route-map TEST permit 10
Ex. 2:
access-list 5 permit 1.1.1.0 0.0.0.255
route-map TEST deny 5
match ip address 5
For some reason, I get caught on the deny clause. When it denies, does it actually deny those routes from being processed at all? If I were to apply the first example to a neighbor for bgp, would the 1.1.1.0 not show up in the routing table? It seems like it doesn't, but I want to make sure that I'm looking at this right.
*Edit: Actually, the route map doesn't stop the route from being put into the table. Are the deny statements ONLY for processing weights, metrics, etc, and if I need to deny a route from getting into the table, I should use a distribution list?
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello John,
when you use a route map deny statement if a prefix is permitted by the ACL it is actually filtered.
but if you have a route map deny statement with an ACL that denies a prefix that prefix is not filtered but left in basket and so can be permitted by the second clause.
So the two route-maps do different things:
first route-map allows only prefix 1.1.1.0/24 as a result of denying it and the permit any that will cause all other prefixes to be denied.
second route-map denies 1.1.1.0/24 and allows all other prefixes with second clause.
Hope to help
Giuseppe
Giuseppe,
Would you say that the second example would act like a distribution list filter?
John
Hello John,
second route-map is equivalent to apply the acl 5 of first example as a distribute-list.
This looks like strange, isn't it?
Hope to help
Giuseppe
