Route Redistribution
1lumkk
Level 2
Level 2
I had three routers, R1, R2 & R3. R1 to R2 will run EIGRP. R1 to R3 will run OSPF. I managed to redistribute ospf to eigrp on R1. However, I failed to redistribute eigrp into ospf on R1. Hence, the R3 is not able to see eigrp subnets from R2.
Connection:
R2<--eigrp--->R1<--ospf-->R3
Attached is the config. Has any1 got any idea what went wrong?
mohammedmahmoud
Level 11
Level 11
Can you please add the word "subnets" to the redistribution command under the OSPF process on R1.
BR,
Mohammed Mahmoud.
