Route Selection when BGP redistributed into OSPF
amvita
I have two routers R1 and R2 each connected to a different MPLS-VPN cloud. R1 is running eBGP to the PE router and OSPF to a Core router in the LAN. R2 is also running eBGP to the PE router but it is also running iBGP to another router R3. R3 is connected to the Core LAN router and is running OSPF. When I redistribute the BGP into the OSPF process on R1 and R3, the routes that get inserted into the routing table on the Core Lan router are always those from R1 (running eBGP).
I need to prefer the routes from R3 in the LAN Core. How can I do this?
The problem you are running into is due to Admin distance factor. On R3, the IBGP learnt route has an admin distance of 200 whereas the OSPF route's admin distance is only 110 and hence, it's preferred over the IBGP route. This results in R3 not redistributing the IBGP route into OSPF at all.
Try configuring the distance as follows on R3:
router bgp 23146
distance bgp 20 109 109
I haven't used the distance BGP command myself before but I think this should work. Issue the commands, clear ip bgp * soft & clear ip route * and check the status again on your LAN core router. There might be a very brief disruption when the clear ip route * command is issued.
Sundar
7 Replies 7
Harold Ritter
Are you certain the routes from R3 are even redistributed into OSPF. By default iBGP routes will not be redistributed into OSPF. You need to use the "bgp redistribute-internal" knob to allow iBGP routes to be redistributed into any IGP.
Also, once that is done, you can set the metric-type to 1 as you redistribute on R3 and set it to 2 on R1. This way routes from R3 will always be preferred over the same routes from R1.
Hope this helps,
Hope this helps,
Thanks for the reply.
I am using the "bgp redistribute-internal" command on R3. I've also added the metric-type setting on both routers, but the LAN core still prefers the route through R1. (*note: the configuration on R1 does not reflect the metric-type 2 configuration. Default metric-type = 2)
Here's the updated config...
**R3***
router ospf 1
log-adjacency-changes
redistribute connected
redistribute bgp 64609 metric-type 1 subnets
passive-interface GigabitEthernet0/1
network 10.2.203.96 0.0.0.31 area 2
network 10.2.203.128 0.0.0.31 area 2
router bgp 64609
no synchronization
bgp log-neighbor-changes
redistribute ospf 1
neighbor 10.2.203.114 remote-as 64609
neighbor 10.2.203.114 soft-reconfiguration inbound
no auto-summary
**R1**
router ospf 1
auto-cost reference-bandwidth 4294967
redistribute bgp 65009 subnets route-map OSPF-REDISTRIBUTE-BGP
network 10.2.1.16 0.0.0.15 area 2
network 10.2.1.128 0.0.0.15 area 2
network 10.2.255.254 0.0.0.0 area 2
router bgp 65009
no synchronization
network 10.2.1.16 mask 255.255.255.240
network 10.2.1.128 mask 255.255.255.240
network 10.2.255.254 mask 255.255.255.255
redistribute ospf 1
neighbor 12.113.143.241 remote-as 7018
neighbor 12.113.143.241 soft-reconfiguration inbound
neighbor 12.113.143.241 prefix-list LOCAL-TO-BGP out
no auto-summary
ip access-list standard BGP-OSPF-IN
permit 10.7.252.1
permit 10.7.250.0 0.0.0.255
permit 10.7.251.0 0.0.0.255
route-map OSPF-REDISTRIBUTE-BGP permit 10
match ip address BGP-OSPF-IN
**LAN Core**
LAN-CORE>sho ip route 10.7.252.1
Routing entry for 10.7.252.1/32
Known via "ospf 2", distance 110, metric 1
Tag 7018, type extern 2, forward metric 1
Last update from 10.2.1.130 on GigabitEthernet13/47, 00:02:56 ago
Routing Descriptor Blocks:
* 10.2.1.130, from 10.2.255.254, 00:02:56 ago, via GigabitEthernet13/47
Route metric is 1, traffic share count is 1
Can you post the output of 'show ip ospf database external 10.7.252.1' from the core router.
I see what the issue is now. It is most probably a timing issue.
Let me explain. You are doing mutual redistribution. On R3, the routes learnt via OSPF are redistributed into BGP before BGP can redistribute them into OSPF, which would explain why LAN-CORE doesn't see the route being advertised by R3 via OSPF. You should use filtering as you redistribut from OSPF to BGP.
To verify this, issue a "sh ip bgp 10.7.252.1" on R3 and you should see this route as being locally originated (bgp next-hop = 0.0.0.0).
Hope this helps,
This is output from the LAN Core router. Notice that there is only 1 OSPF DB entry and it is comming from R1.
LAN-CORE>#sho ip ospf data ext 10.7.252.1
OSPF Router with ID (216.115.178.2) (Process ID 2)
Type-5 AS External Link States
Routing Bit Set on this LSA
LS age: 981
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 10.7.252.1 (External Network Number )
Advertising Router: 10.2.255.254
LS Seq Number: 8000002B
Checksum: 0xF8F0
Length: 36
Network Mask: /32
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 1
Forward Address: 0.0.0.0
External Route Tag: 7018
Here is the "sh ip bgp 10.7.252.1 from R3. It is indicating the correct "next-hop" address, but a rib-failure. The "sh ip ospf data ext 10.7.252.1" displays the route being learned from R1.
R3>#sho ip bgp 10.7.252.1
BGP routing table entry for 10.7.252.1/32, version 3565
Paths: (1 available, best #1, table Default-IP-Routing-Table, RIB-failure(17))
Not advertised to any peer
13979 64603, (received & used)
10.2.203.114 from 10.2.203.114 (172.24.39.9)
Origin IGP, localpref 100, valid, internal, best
R3>#sho ip ospf data ext 10.7.252.1
OSPF Router with ID (10.2.203.133) (Process ID 1)
LS age: 167
LS Seq Number: 80000031
Checksum: 0xECF6
Length: 36
Network Mask: /32
TOS: 0
Metric: 1
Is this what you'd expect to see in this scenario? I will be filtering out the OSPF redistribution into BGP on R3 such that only the local LAN segments (those that are originated from LAN Core) are redistributed.
router bgp 23146
Sundar
Thanks to all who responded to this post.
The fix to this issue was a combination of setting the metric-type to 1 on R3 and also changing the AD for BGP internal and local routes on R3 to be less than that of ospf
Resulting configuration on R3 (obvious commands omitted):
router ospf 1
router bgp 64609
redistribute ospf 1
The resulting routes on the LAN Core:
LAN-CORE># sho ip route 10.7.252.1
Known via "ospf 2", distance 110, metric 2
Tag 13979, type extern 1
Last update from 10.2.203.133 on Vlan308, 00:00:18 ago
* 10.2.203.133, from 10.2.203.133, 00:00:18 ago, via Vlan308
Route metric is 2, traffic share count is 1
LAN-Core>#sho ip route 10.7.252.1
Last update from 10.2.203.133 on Vlan308, 00:06:56 ago
* 10.2.203.133, from 10.2.203.133, 00:06:56 ago, via Vlan308
LAN-Core>#sho ip ospf data ext 10.7.252.1
LS age: 551
Advertising Router: 10.2.203.133
LS Seq Number: 80000003
Checksum: 0x4EA5
Length: 36
Network Mask: /32
Metric Type: 1 (Comparable directly to link state metric)
TOS: 0
Metric: 1
External Route Tag: 13979
LS age: 628
LS Seq Number: 80000034
Checksum: 0xE6F9
Length: 36
Network Mask: /32
TOS: 0
Metric: 1
Last update from 10.2.203.133 on Vlan308, 00:09:29 ago
* 10.2.203.133, from 10.2.203.133, 00:09:29 ago, via Vlan308
