route sub interface
Manish Manwal
we have create three vlan in our network. then we done inter vlan routing through cisco 3850 l3 switch.
we want to sent traffic all of vlan out of our network through router.
all vlan default gatway configured in cisco 3850.
configured link l3 switch to router as trunk.
configured router subinterface with respective vlan gatway network.
but it cant send traffic
it sh that sub interface is administratively down.
THANKS
MANISH MANWAL
Manish Manwal
GigabitEthernet0/1.1 10.10.32.2 YES manual administratively down down
THANKS
MANISH MANWAL
Hello
configured router sub-interface with respective vlan gateway network.
It seems to have configure the rtr and the switch to perform the same routing -  As you have the switch already doing this then there is no need to create sub-interfaces on the rtr
You will only need the switchport connecting to the rtr as an access port and assigned to one the vlans you have already created
On the rtrs lan interface assign it an ip address from the same vlan the its switchport is connected to.
res
Paul
Kind Regards
Paul
