Route Tagging and Redistribution Loops
Mitrixsen
Hello, everyone!
If my understanding here is correct, Route Tagging is used to prevent redistribution loops where routes are being redistributed from, for example, Protocol A -> Protocol B -> back to Protocol A.
Source: NetworkLessons.com
However, I've encountered some confusion here about how these redistribution loops even happen. Take a look at this scenario
There really does appear to be a loop because R1 also considers the path through
G0/1
as valid for the
192.168.1.0/24
destination.
However, in the next scenario
Nor EIGRP or OSPF are encountering any of these redistribution loops that are supposed to happen if no tagging is configured. R1 has just a single route which leads to the correct destination.
So how exactly do these loops even work? Why is it that with OSPF and EIGRP, the routes are not getting redistributed back into them, while they do with RIP?
Thank you in advance for your help.
David
Giuseppe Larosa
Hello David @Mitrixsen ,
Both EIGRP and OSPF are able to distinguish internal routes from external routes and EIGRP uses different AD 170 for D EX prefixes. OSPF uses a single AD but it uses  an ordered list of preferences
O > O IA > O Ex  , O E1 are preferred over O E2 prefixes
EIGRP internal routes AD is 90 < OSPF AD 110.
However, mutual redistribution in two routers of two dynamci protocols is a dynamic process too , that does not happen once but it occurs over time.
A safe configuration must be able to deal with whatever event happens.
In your example what happens if the interface directly connected to
192.168.1.0/24
in EIGRP domain is shut down ?
EIGRP uses its own way and it goes active for the
prefix
during the time this happens OSPF can
re-inject the prefix
into EIGRP domain for the redistribution.
The purpose of the route tags when used correctly is to manage all scenarios and to avoid unwanted
re-injections of prefixes
in the IGP that should be origin of the route.
So if the OSPF route is tagged with a route tag value that is denied in redistributing into EIGRP this
re-injection
does not occur.
The route tag is an integer  32bit value for OSPF, EIGRP and IS-IS it might be 16 bit value for RIPv2.
Hope to help
Giuseppe
Giuseppe Larosa
192.168.1.0/24
prefix
re-injection
does not occur.
Hope to help
Giuseppe
M02@rt37
Hello @Mitrixsen,
EIGRP implement a mechanism known as
split horizon
to avoid redistribution loops by default. The split horizon rule dictates that routes learned from one routing protocol should not be readvertised back into the same routing protocol. Due to the split horizon rule, EIGRP will not readvertise routes that they have learned via redistribution back into the same OSPF or EIGRP domain. As a result, redistribution loops are naturally avoided.
In OSPF, there is no built-in mechanism like
split horizon
to prevent redistribution loops. OSPF redistributes external routes into the OSPF domain by default, which could lead to potential redistribution loops if there are multiple redistribution points. In the second scenario you mentioned that there are no redistribution loops even though R1 receives routes from both EIGRP and OSPF. The reason for this behavior is due to the default OSPF behavior for Type 2 external routes. When redistributing routes into OSPF, they are treated as Type 2 external routes by default. Type 2 external routes have a fixed cost (metric) within OSPF, and OSPF will not readvertise them back into the same OSPF domain. This behavior prevents redistribution loops for Type 2 external routes.
By tagging the redistributed routes and filtering them during redistribution, you can prevent certain routes from being readvertised back into OSPF, providing additional control over the redistribution process.
RIP, on the other hand, does not have built-in mechanisms to prevent redistribution loops. When RIP receives routes from another routing protocol (such as OSPF or EIGRP), it will readvertise them back into the RIP domain. This is why redistribution loops are more likely to occur with RIP than with EIGRP or OSPF.
Best regards
Hello
You can use
route map
tagging to negate
route-reeedback
from either IGPs
Example:
route-map OSPFintoEIGRP deny 10 -( eigrp routes- now ospf routes with a tag of 90 will be denied from going back into eigrp
match tag 90
route-map OSPFintoEIGRP permit 99 - ( All other OSPF routes are tagged with 110 into eigrp)
set tag 110
route-map EIGRPintoOSPF deny 10 - (ospf routes- now eigrp routes with a tag of 110 will be denied from going back into ospf
match tag 110
route-map EIGRPintoOSPF permit 99 - ( All other eigrp routes are tagged with 90 into ospf)
set tag 90
Kind Regards
Paul
